Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » ASTNode sourceStart and sourceEnd - running offset?
ASTNode sourceStart and sourceEnd - running offset? [message #23317] |
Tue, 06 May 2008 15:01  |
Every DLTKToken has the members:
line
column
text (from which you can get text.length())
Please note that line is *never* read.
ASTNode has the members:
sourceStart
sourceEnd
These are initialized in the constructor to be:
protected ASTNode(DLTKToken token) {
this.sourceStart = token.getColumn();
String tokenValue = token.getText();
if (tokenValue != null) {
this.sourceEnd = this.sourceStart + tokenValue.length();
If this node is all on the first line, this makes sense.
If the node does not start on the first line or spans multiple lines, this
doesn't make sense.
Somehow you need to determine a running offset from the start of the source
module.
I don't see where/how that is done.
Later, in ASTNode, is getSourceRange:
protected ISourceRange getSourceRange() {
return new SourceRange(this.sourceStart(), this.sourceEnd() -
this.sourceStart() + 1);
Here's what the documentation for ISourceRange says:
A source range defines an element's source coordinates relative to its
source buffer.
int getOffset()
Returns the 0-based index of the first character of the source
code for this element, relative to the source buffer in which this element
is contained.
int getLength()
Returns the number of characters of the source code for this
element, relative to the source buffer in which this element is contained.
Re: ASTNode sourceStart and sourceEnd - running offset? [message #23494 is a reply to message #23317] |
Wed, 07 May 2008 13:18   |
I think I found the answer to my question, in DLTKTokenConverter, which was
used in the Python tutorial code.
As I said in my previous post, DLTKToken.col (and getColumn()) are actually
used to capture the offset into the buffer, not the column on the line.
This is very misleading.
Please note that although Antlr Lexer depends on the Token interface, it
actually uses CommonToken which has a getStartIndex and getStopIndex.
Also, DLTKTokenConverter populates DLTKToken with a line index (0 based)
rather than a line number (1 based). However, this is moot since there is no
public method to fetch the line number or index (but there is a method to
set it).
FYI - I ultimately determined that this problem was the reason why when I
clicked on a declaration name in the outline view of my editor that the
editor was unable to highlight the selected item. I am changing my grammar
now to properly set the start/end index/offset into the buffer (rather than
the column or character position in the line).
Chuck
"Chuck Doucette" <cdoucette@vaultus.com> wrote in message
news:fvqa0c$2dp$1@build.eclipse.org...
> line
> column
> sourceStart
> sourceEnd
> doesn't make sense.
> source module.
> source buffer.
> int getOffset()
> is contained.
> int getLength()
Re: ASTNode sourceStart and sourceEnd - running offset? [message #23877 is a reply to message #23317] |
Mon, 12 May 2008 10:44   |
Hi Chuck,
In the beginning of DLTK and Python support, ASTNode class was constructor with ANTLR Token parameters.
Then we move to Eclipse, we removed ANTLR dependency from core and created this wrapper class. It is only used from
Python parser. Better idea it is not to use it at all, as we do in Tcl and Ruby.
I suppose for some problems you described we have for some Python statements.
I suppose better idea for you is not to use DLTKToken at all. I've marked this class as deprecated in HEAD.
Andrei Sobolev.
> line
> column
> sourceStart
> sourceEnd
> doesn't make sense.
> module.
> source buffer.
> int getOffset()
> is contained.
> int getLength()
Re: ASTNode sourceStart and sourceEnd - running offset? [message #23918 is a reply to message #23494] |
Mon, 12 May 2008 10:49   |
Hi Chuck,
In Outline DLTK used structure model elements to point to code locations. If you use SourceElementRequestVisitor like
method to build structure model for types, method, etc. it uses Declaration.getNameStart(), getNameEnd() methods of
TypeDeclaration and MethodDeclaration.
Andrei Sobolev.
> set it).
> Chuck
>> line
>> column
>> sourceStart
>> sourceEnd
>> doesn't make sense.
>> source module.
>> source buffer.
>> int getOffset()
>> is contained.
>> int getLength()
Re: ASTNode sourceStart and sourceEnd - running offset? [message #23995 is a reply to message #23877] |
Tue, 13 May 2008 12:08   |
Thank you for the information.
I followed the model in the Example Python parser since that's the tutorial
that was recommended to follow (although the parser was not specifically
discussed in the tutorial).
I will look at the source code for TCL and Ruby and see what they do
instead.
Chuck
"Andrei Sobolev" <haiodo@xored.com> wrote in message
news:g09l3j$omi$1@build.eclipse.org...
> Hi Chuck,
> Ruby.
> statements.
> Best regards,
> Andrei Sobolev.
>> line
>> column
>> sourceStart
>> sourceEnd
>> this
>> doesn't make sense.
>> source
>> module.
>> source buffer.
>> int getOffset()
>> element
>> is contained.
>> int getLength()
>> contained.
Re: ASTNode sourceStart and sourceEnd - running offset? [message #27995 is a reply to message #23918] |
Thu, 10 July 2008 14:13  |
One issue with
a) not having DLTKToken.getLine
b) not having a line number member in ASTNode (which could be set by calling
DLTKToken.getLine())
is that all problems listed in the problems view have line #1.
Fortunately, the correct text is still underlined because the buffer offsets
are tracked.
Chuck
news:g09le7$ubd$1@build.eclipse.org...
> Hi Chuck,
> Best regards,
> Andrei Sobolev.
>> was
>> actually
>> no
>> set it).
>> grammar
>> than
>> Chuck
>>> line
>>> column
>>> sourceStart
>>> sourceEnd
>>> this
>>> doesn't make sense.
>>> source module.
>>> source buffer.
>>> int getOffset()
>>> element
>>> is contained.
>>> int getLength()
>>> contained.
Current Time: Tue Jul 22 01:43:43 EDT 2025
Powered by FUDForum. Page generated in 0.07054 seconds
