Home » Archived » Memory Analyzer (MAT) » Blog: Immortal Objects - Or: How to Find Memory Leaks
Blog: Immortal Objects - Or: How to Find Memory Leaks [message #1989] Mon, 21 April 2008 13:14 Go to next message
just wanted to let you know about the blog I just posted:
http://dev.eclipse.org/blogs/memoryanalyzer/2008/04/21/immor tal-objects-or-how-to-find-memory-leaks/
While searching for a good blog topic, I came across a Bugzilla entry
detailing a leak in WorkbenchWindow. I thought, why not give it a try? It
turned out to be a one line fix (a missing dispose()). Then I retraced
every step I did, took a couple of screenshots and jotted down a couple of
lines to explain what I did.
Let me know what you think!
Andreas.
Re: Blog: Immortal Objects - Or: How to Find Memory Leaks [message #2003 is a reply to message #1989] Tue, 22 April 2008 03:34 Go to previous messageGo to next message
Originally posted by: joerg.von.frantzius.artnology.com
Very nice article! That should definitely attract some people to the
Memory Analyzer, as it deserves :)
By the way, what does the "T" stand for in "MAT"?
Andreas Buchen schrieb:
> It turned out to be a one line fix (a missing dispose()). Then I
> retraced every step I did, took a couple of screenshots and jotted
> down a couple of lines to explain what I did.
> Andreas.
Re: Blog: Immortal Objects - Or: How to Find Memory Leaks [message #2016 is a reply to message #2003] Tue, 22 April 2008 07:27 Go to previous message
T as in Tool
As always, giving the thing a name is not easy. And the class name
org.eclipse.memoryanalyzer would have been too long even with code
completion. :-/
Andreas.
Previous Topic:EclipseCon Long Talk a/b Memory Analyzer
Next Topic:Static fields and heap usage
Current Time: Wed Nov 19 06:24:14 EST 2025
Powered by FUDForum. Page generated in 0.04656 seconds
