Help setting up generic web connector [message #23275] |
Mon, 20 August 2007 18:26  |
Originally posted by: markphip.GoogleMail.com
I am trying to use the generic web connector. Are there any
techniques for figuring out what is happening? For example, my
repository requireslogin and for all I know my problem is that I did
not configure that
correctly.
I am getting errors that I need to check my query regexp, but it
seemslike it could just as easily be a login problem.
Are there any tools you used to test your regex? I assume you
wouldwant to paste the source of the web page in some tool and then run
the expression to see what it gives back.
I am trying to match something like this:
<td> artf25589 :
Deliver Product Training </td>
I am currently trying this:
Mark
I'm trying a new usenet client for Mac, Nemo OS X.
You can download it at http://www.malcom-mac.com/nemo
Re: Help setting up generic web connector [message #577966 is a reply to message #23275] |
Mon, 20 August 2007 22:23  |
Mark,
There isn't really much tools, but we have few hints on the wiki about
troubleshoting
http://wiki.eclipse.org/Mylyn_FAQ#Why_can.27t_I_connect_usin g_one_of_the_existing_templates.3F
The easiest could be to use wget to get content of the page and then
try regexp in Eclipse text editor.
While back someone seem wanted to contribute some debugging features,
but I haven't heard back about that...
regards,
Eugene
> not configure that
> correctly.
> <td> artf25589 :
> Thanks
> Mark
FUDForum. Page generated in 0.03730 seconds
