Advice wanted on sharing projects [message #237395] |
Thu, 11 October 2007 17:11  |
Up until now we have not been basing our projects on existing source.
Recently we have started doing this so the .settings folder, .classpath,
fbprefs, .project files, etc are checked into source control. We use
perforce and not everyone has their client-spec set to root their source
at the same place.
So the problem is that when people try to create a project from existing
sources, the paths in the .classpath, .projects, etc do not point to the
same place.
Is there some way to specify a root directory for things in your project
so references to things like jar files is relative and not abolute?
What best practices do people use when sharing code from source
repositories?
Re: Advice wanted on sharing projects [message #237596 is a reply to message #237549] |
Sat, 13 October 2007 14:13  |
Thanks, that seems to be confirmed by my colleages who are creating
projects from existing sources (according to my new documentation) and
delighted with how much better it is than the old way of keeping the
classpath and .project files in the workspace.
This forum needs some sort of system like Sun's dukes for awarding people
who provide truely helpful answers.
Thanks again.
David Wegener wrote:
> Class path and Link path variables are stored in the workspace. The
> ..project file only contains the variable name. You have to define the
> variable in the workspace for the link to be resolvable.
FUDForum. Page generated in 0.11665 seconds
