Home » Archived » M2M (model-to-model transformation) » [ATL] Re: Pass a parameters in atl command lines
[ATL] Re: Pass a parameters in atl command lines [message #23239] Tue, 13 March 2007 06:29 Go to next message
Originally posted by: freddy.allilaire.univ-nantes.fr
Hi Yassin,
Please use the M2M newsgroup for ATL-specific questions. I've added it
to the "to" list, so you can continue to use this thread.
I have never used this command-line tool :-( but maybe Dennis could help
you on this newsgroup :-).
Freddy.
yassin a écrit :
> Hello,
> I run the ATL Transformation from the command line as an own application
> outside Eclipse. I'm using the ATL Command-Line done by Dennis
> ( http://ssel.vub.ac.be/viewcvs/viewcvs.py/UML1CaseStudies/uml 1cs-atlcommandline/src/org/atl/commandline/Main.java?view=ma rkup)
> I want to pass a parameters with this Main to run my program, and i want
> to know if "ATL Command-Line done by Dennis" support more than one model
> "in".
> someone can give me some information ???
> I hope that you understood well my question and afflicted for my English
> level writing .
> Thanks in advance
> Yassin
Freddy Allilaire - ATLAS Group (INRIA & LINA)
http://www.sciences.univ-nantes.fr/lina/atl/contrib/allilair e
Re: [ATL] Re: Pass a parameters in atl command lines [message #23364 is a reply to message #23239] Tue, 13 March 2007 14:00 Go to previous messageGo to next message
Freddy Allilaire schreef:
> Hi Yassin,
> Freddy.
> yassin a écrit :
>> Hello,
>> application outside Eclipse. I'm using the ATL Command-Line done by
>> Dennis
>> want to know if "ATL Command-Line done by Dennis" support more than
>> one model "in".
>> English level writing .
>> Thanks in advance
>> Yassin
It does support more than one "in", "out", "lib", etc. It also supports
doing more than one transformation. A good example can be found here:
http://ssel.vub.ac.be/viewcvs/viewcvs.py/UML1CaseStudies/uml 1cs-instantmessenger-model/outmodels/test2mm/build.xml?rev=5 387&view=markup
This example calls the ATL command line tool from an Ant script.
Kind regards,
Dennis
Re: [ATL] Re: Pass a parameters in atl command lines [message #23451 is a reply to message #23364] Wed, 14 March 2007 05:18 Go to previous messageGo to next message
Originally posted by: yassin_chkouri.yahoo.fr
I made a program in ATL which makes the fusion of the components, and
which takes in parameter the names of the components merged. starting from
the class 'luncher' that you used in your "Main", this class with
parameter: “trans”, “libs”, “models” and "params". I want to know how I
can used this “params”? how I will make to call this “params” in my
program ATL? I already used the passage of parameter by a file XML, and I
can launch my program ATL but without paramter (thanks to your Main
function) but separately.
thank you in advance
Re: [ATL] Re: Pass a parameters in atl command lines [message #24055 is a reply to message #23451] Sun, 18 March 2007 15:31 Go to previous message
> from the class 'luncher' that you used in your "Main", this class with
> parameter: �trans�, �libs�, �models� and "params". I want to know how I
> can used this �params�? how I will make to call this �params� in my
> I can launch my program ATL but without paramter (thanks to your Main
The "params" parameter in AtlLauncher.launch() is not used in the
command line interface, the Eclipse interface or the Ant interface. Are
you sure you even need this?
If you just want to know what to do with this parameter, then just do
the same as the command line tool: pass Collections.EMPTY_MAP into it.
If you want to pass parameters to your transformation, it's better to
store your parameters in an XML model:
http://wiki.eclipse.org/index.php/ATL_Howtos#How_do_I_use_ex tern_parameters_in_ATL_transformations.3F
Dennis
Previous Topic:UML1.3 To IF Transformation
Next Topic:ATL out of eclipse
Current Time: Wed Nov 05 18:51:57 EST 2025
Powered by FUDForum. Page generated in 0.03893 seconds
