| Error from debug UI [message #236505] |
Wed, 27 September 2006 07:35  |
Originally posted by: filmil.REALLY.NO.SPAM.gmail.com
Greetings.
Again I'm having a problem with Debug UI as before (see:
http://dev.eclipse.org/newslists/news.eclipse.tools.jdt/msg1 8856.html ).
[I paste the text from the original message before, but the text I get
now is similar]
> Trying to follow a stack trace to an offending program line, Eclipse 3.2
> says the following. I see that there's a resource /openmap/src missing.
> This is OK because I moved openmap around, so I suspect this has to do
> with a stale path somewhere in Eclipse's configuration files. I want
> remove the stale path but don't know where I should look for it.
> Advice appreciated.
> f
>> !ENTRY org.eclipse.jdt.debug.ui 4 150 2006-08-07 13:04:17.400
>> !MESSAGE Internal Error
>> !STACK 1
>> org.eclipse.core.runtime.CoreException: Unable to access archive /openmap/src
>> at org.eclipse.debug.core.sourcelookup.containers.AbstractSourc eContainer.abort(AbstractSourceContainer.java:44)
>> at org.eclipse.debug.core.sourcelookup.containers.ExternalArchi veSourceContainer.getArchive(ExternalArchiveSourceContainer. java:201)
>> at org.eclipse.debug.core.sourcelookup.containers.ExternalArchi veSourceContainer.findSourceElements(ExternalArchiveSourceCo ntainer.java:78)
>> at org.eclipse.debug.core.sourcelookup.containers.CompositeSour ceContainer.findSourceElements(CompositeSourceContainer.java :78)
>> at org.eclipse.debug.core.sourcelookup.containers.CompositeSour ceContainer.findSourceElements(CompositeSourceContainer.java :45)
>> at org.eclipse.debug.core.sourcelookup.AbstractSourceLookupPart icipant.findSourceElements(AbstractSourceLookupParticipant.j ava:67)
>> at org.eclipse.debug.core.sourcelookup.AbstractSourceLookupDire ctor$SourceLookupQuery.run(AbstractSourceLookupDirector.java :136)
>> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
>> at org.eclipse.debug.core.sourcelookup.AbstractSourceLookupDire ctor.findSourceElements(AbstractSourceLookupDirector.java:72 1)
This time starting up eclipse with option -clean does not help. And the
other advice, finding "Clear configuration..." does not work as in my
Eclipse I cannot find the toggle when opening Run->Run...
Advice is appreciated.
f
| Re: Error from debug UI [message #236887 is a reply to message #236505] |
Wed, 27 September 2006 08:16   |
--------------090608050104020902010600
Content-Type: text/plain; charset=UTF-8; format=flowed
Filip,
I doubt this has anything to do the with the configuration. Maybe you
still have a stale source attachment specified?
Filip Miletic wrote:
>Greetings.
>now is similar]
>>Advice appreciated.
>>f
>>>!STACK 1
>f
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Filip,<br>
<br>
still have a stale source attachment specified?<br>
<br>
<br>
<blockquote cite="midefdnmf$rim$1@utils.eclipse.org" type="cite">
<pre wrap="">Greetings.
<a class="moz-txt-link-freetext" href=" http://dev.eclipse.org/newslists/news.eclipse.tools.jdt/msg1 8856.html"> http://dev.eclipse.org/newslists/news.eclipse.tools.jdt/msg1 8856.html</a> ).
now is similar]
</pre>
<blockquote type="cite">
<pre wrap="">Trying to follow a stack trace to an offending program line, Eclipse 3.2
Advice appreciated.
f
</pre>
<pre wrap="">!ENTRY org.eclipse.jdt.debug.ui 4 150 2006-08-07 13:04:17.400
!STACK 1
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
f
</pre>
</blockquote>
<br>
</body>
</html>
--------------090608050104020902010600--
| Re: Error from debug UI [message #237002 is a reply to message #236964] |
Fri, 29 September 2006 11:14  |
Ed Merks wrote:
> I don't know all the inner workings... Maybe looking directly in the
> .classpath files if it doesn't turn up in any dialogs.
Thanks. This was the winning combo.
I found the stale entry in one of the classpaths. It would be great if
the Debug UI would also point at the place where the offending entry has
been found, instead of letting the user figure it out.
f
FUDForum. Page generated in 0.05431 seconds
