Home » Modeling » M2T (model-to-text transformation) » run jet2 outside of eclipse
run jet2 outside of eclipse [message #23139] Wed, 20 June 2007 14:04 Go to next message
Hi Paul,
Just one question, is it possible to run jet2 outside of Eclipse?
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: run jet2 outside of eclipse [message #23216 is a reply to message #23139] Thu, 21 June 2007 00:44 Go to previous messageGo to next message
Originally posted by: evaandoli.dodo.com.au
A previous reply from Paul on this:
Frederic:
Thanks for the feedback.
I cannot guarantee that the refactoring will be completed by this June's
release - in particular, it is unlikely I'll have tag libraries that will
work outside of a full workbench.
The JET 0.8.0M6 build has a new plug-in, org.eclipse.jet.core, which is
largely free of Eclipse dependencies (except for org.eclipse.text - I will
have to remove some deprecated methods to eliminate that). But,
org.eclipse.jet.core does not yet include any tag library implementations,
nor does it include equivalents to JET2Platform.runTransformXXX().
Paul
"Frederic" <f.bighelli@diginext.fr> wrote in message
news:96be233fbcd1d8b51996c99af133c4b8$1@www.eclipse.org...
> Thanks for your response.
> Do you have a dead line for the first refactored version of JET2?
> For your question,i suggest yes for a subset (tag copyfile,file and
> folder) of JET Workspace in particular case where the target environment
> is outside Eclipse
> environment (this is my case and... sometimes there is no other
> possibility).
"Martin Taal" <mtaal@elver.org> wrote in message
news:f5bq7o$7vc$1@build.eclipse.org...
> Hi Paul,
> The Netherlands
Re: run jet2 outside of eclipse [message #23633 is a reply to message #23139] Fri, 22 June 2007 10:07 Go to previous messageGo to next message
Martin:
So my question to you is, how outside do you want to be?
Is a dependency on Equinox OK? Or, do you want only dependencies on pure
Java?
I am very likely to try to do something in the next release, but I'm not
clear yet on what the community wants or needs.
You feed back would be much appreciated.
Paul
> Hi Paul,
> The Netherlands
Re: run jet2 outside of eclipse [message #23757 is a reply to message #23633] Sun, 24 June 2007 14:28 Go to previous message
Paul,
I prefer only dependencies on pure java and possibly some generic java libs (commons-logging etc.).
I want to use jet for generation of jsf web views. Btw, I just mean the actual transformation. So
the templates are developed/created in an eclipse environment.
gr. Martin
Paul Elder wrote:
> Martin:
> Java?
> Paul
>> Hi Paul,
>> The Netherlands
The Netherlands
Previous Topic:JET in GMF Project
Next Topic:c:iterate with delimiter and formatting
Current Time: Wed Nov 05 08:53:16 EST 2025
Powered by FUDForum. Page generated in 0.02947 seconds
