Workflow runner having trouble finding packages [message #236413] |
Fri, 17 July 2009 17:36 |
I have an Ecore file with the root package called: First and a NS URI of
"http:///First.ecore"
In the ecore model there is a sub-package to First called Second, which
has a NS URL of "http:///First/Second.ecore"
In my runtime workbench I created a diagram using this model and saved
the result to XMI. I then copied this XMI file into my development
workbench so I could run a workflow to generate text from xPand.
However when I run the Workflow runner, it complains it can't find the
http:///Frist/Second.ecore package.
The XMI file does explicitly reference the above NS.
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:First.Second="http:///First/Second.ecore" etc.... >
If I look in the 'Metamodel Explorer' there is only a
http:///Frist.ecore registered. Not http:///Frist/Second.ecore. I must
admit I'm not too sure exactly what a 'Package' is? Is it something this
is registered and would show up in the Metamodel Explorer?
So I guess I'm trying to figure out what to do about this... how do I
enable the resolution of the various items that are referenced from my
XMI file?
I am quite puzzled, any help would be wonderful!
STACK:
Jul 17, 2009 4:18:11 PM org.eclipse.emf.mwe.core.WorkflowRunner
executeWorkflow
SEVERE: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with
uri 'http:///Frist/Second.ecore' not found.
(platform:/resource/project/test/uber.xmi, 3, 60)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException:
org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:315)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:274)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:397)
at org.eclipse.emf.mwe.utils.Reader.load(Reader.java:53)
at org.eclipse.emf.mwe.utils.Reader.invokeInternal(Reader.java: 36)
org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invok e(AbstractWorkflowComponent.java:118)
org.eclipse.emf.mwe.core.container.CompositeComponent.intern alInvoke(CompositeComponent.java:101)
org.eclipse.emf.mwe.core.container.CompositeComponent.invoke (CompositeComponent.java:86)
org.eclipse.emf.mwe.core.WorkflowRunner.executeWorkflow(Work flowRunner.java:412)
at org.eclipse.emf.mwe.core.WorkflowRunner.run(WorkflowRunner.j ava:292)
at org.eclipse.emf.mwe.core.WorkflowRunner.main(WorkflowRunner. java:239)
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package
with uri 'http:///Frist/Second.ecore' not found.
org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(X MLHandler.java:2590)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefi x(XMLHandler.java:2421)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:1299)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:1468)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1019)
org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:87)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:1001)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:712)
org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:169)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(AbstractSAXParser.java:533)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.j ava:878)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDispatcher.dispatch(XMLDocumentFra gmentScannerImpl.java:1693)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java: 368)
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:834)
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:764)
com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(X MLParser.java:148)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(AbstractSAXParser.java:1242)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:375)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1494)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1282)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:255)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:270)
... 9 more
FUDForum. Page generated in 0.36926 seconds
