Home » Language IDEs » PHP Development Tools (PDT) » No build of projects (no outline, no completion, no ctrl+click)
No build of projects (no outline, no completion, no ctrl+click) [message #23138] |
Wed, 23 May 2007 03:55  |
Hi all,
I have been using PDT for a pretty while now, and I recently installed
the latest (0.7-RC3, all in one w32 package) build at work (I had the
latest version at home), but somehow none of the code-insight functions
work; no outline, no tooltips, no syntax checking no autocompletion,
etc, etc (in PHP files that is, WTP files do work as expected)
I installed it in a separate folder than the previous version i had had
installed (eclipse 3.1 / phpeclipse) and I created a new workspace. To
be exact; I moved (not copied) eclipse 3.1 to a folder eclipse-backup
and installed 3.2 / pdt in the eclipse folder again so I wouldn't have
to change any shortcuts or whatever. I have no extra plugins installed.
I should also mention that I tested this in projects i imported from the
previous version of eclipse I had running.
Anyone any idea where I can look to fix this? Especially syntax checking
is a great miss if you're used to it.
Gerard / drm
PS: Listed version number of the PDT plugins is 0.7.0.v20070401
Re: No build of projects (no outline, no completion, no ctrl+click) [message #23251 is a reply to message #23138] |
Wed, 23 May 2007 16:11   |
Originally posted by: chris.pineconehill.com
drm wrote:
> Hi all,
> Gerard / drm
I'm having the same problem, I'm new to PDT. I haven't been able to get
templates to work and it's been quite frustrating. Almost made me drop
it. Any way to fix it would be great.
Chris
Re: No build of projects (no outline, no completion, no ctrl+click) [message #23354 is a reply to message #23138] |
Thu, 24 May 2007 06:19   |
You can't migrate phpeclipse project to PDT projects.
Guy Gurfinkel,
Team Leader, Development Tools
Zend.
"drm" <drm@melp.nl> wrote in message news:f30s1p$s28$1@build.eclipse.org...
> Hi all,
> I have been using PDT for a pretty while now, and I recently installed the
> latest (0.7-RC3, all in one w32 package) build at work (I had the latest
> version at home), but somehow none of the code-insight functions work; no
> outline, no tooltips, no syntax checking no autocompletion, etc, etc (in
> installed (eclipse 3.1 / phpeclipse) and I created a new workspace. To be
> exact; I moved (not copied) eclipse 3.1 to a folder eclipse-backup and
> installed 3.2 / pdt in the eclipse folder again so I wouldn't have to
> Gerard / drm
Re: No build of projects (no outline, no completion, no ctrl+click) [message #23397 is a reply to message #23354] |
Thu, 24 May 2007 08:06   |
Originally posted by: seva-eclipse.zend.com
You can do it manually:
1. Create new empty PDT Project.
2. Open .project file.
3. Open .project file of existing PHPEclipse project.
4. Replace Nature & Builders in the .project of existing PHPEclipse project with ones from newly created PDT project.
Done.
On Thu, 24 May 2007 13:19:33 +0300 "Guy Gurfinkel" <guy.g@zend.com> wrote:
GG> You can't migrate phpeclipse project to PDT projects.
GG>
GG>
GG> --
GG> Guy Gurfinkel,
GG> Team Leader, Development Tools
GG> Zend.
GG>
GG> "drm" <drm@melp.nl> wrote in message news:f30s1p$s28$1@build.eclipse.org...
GG> > Hi all,
GG> >
GG> >
GG> > I have been using PDT for a pretty while now, and I recently installed the
GG> > latest (0.7-RC3, all in one w32 package) build at work (I had the latest
GG> > version at home), but somehow none of the code-insight functions work; no
GG> > outline, no tooltips, no syntax checking no autocompletion, etc, etc (in
GG> > PHP files that is, WTP files do work as expected)
GG> >
GG> > I installed it in a separate folder than the previous version i had had
GG> > installed (eclipse 3.1 / phpeclipse) and I created a new workspace. To be
GG> > exact; I moved (not copied) eclipse 3.1 to a folder eclipse-backup and
GG> > installed 3.2 / pdt in the eclipse folder again so I wouldn't have to
GG> > change any shortcuts or whatever. I have no extra plugins installed.
GG> >
GG> > I should also mention that I tested this in projects i imported from the
GG> > previous version of eclipse I had running.
GG> >
GG> > Anyone any idea where I can look to fix this? Especially syntax checking
GG> > is a great miss if you're used to it.
GG> >
GG> >
GG> > Thanks,
GG> > Gerard / drm
GG> >
GG> > PS: Listed version number of the PDT plugins is 0.7.0.v20070401
GG>
Seva Lapsha
[slapsha@dev.eclipse.org]
Zend Eclipse Developer
Current Time: Sat Aug 30 19:49:07 EDT 2025
Powered by FUDForum. Page generated in 0.02794 seconds
