Home » Language IDEs » PHP Development Tools (PDT) » No build of projects (no outline, no completion, no ctrl+click)
No build of projects (no outline, no completion, no ctrl+click) [message #23138] Wed, 23 May 2007 03:55 Go to next message
Hi all,
I have been using PDT for a pretty while now, and I recently installed
the latest (0.7-RC3, all in one w32 package) build at work (I had the
latest version at home), but somehow none of the code-insight functions
work; no outline, no tooltips, no syntax checking no autocompletion,
etc, etc (in PHP files that is, WTP files do work as expected)
I installed it in a separate folder than the previous version i had had
installed (eclipse 3.1 / phpeclipse) and I created a new workspace. To
be exact; I moved (not copied) eclipse 3.1 to a folder eclipse-backup
and installed 3.2 / pdt in the eclipse folder again so I wouldn't have
to change any shortcuts or whatever. I have no extra plugins installed.
I should also mention that I tested this in projects i imported from the
previous version of eclipse I had running.
Anyone any idea where I can look to fix this? Especially syntax checking
is a great miss if you're used to it.
Gerard / drm
PS: Listed version number of the PDT plugins is 0.7.0.v20070401
Re: No build of projects (no outline, no completion, no ctrl+click) [message #23251 is a reply to message #23138] Wed, 23 May 2007 16:11 Go to previous messageGo to next message
Originally posted by: chris.pineconehill.com
drm wrote:
> Hi all,
> Gerard / drm
I'm having the same problem, I'm new to PDT. I haven't been able to get
templates to work and it's been quite frustrating. Almost made me drop
it. Any way to fix it would be great.
Chris
Re: No build of projects (no outline, no completion, no ctrl+click) [message #23354 is a reply to message #23138] Thu, 24 May 2007 06:19 Go to previous messageGo to next message
You can't migrate phpeclipse project to PDT projects.
Guy Gurfinkel,
Team Leader, Development Tools
Zend.
"drm" <drm@melp.nl> wrote in message news:f30s1p$s28$1@build.eclipse.org...
> Hi all,
> I have been using PDT for a pretty while now, and I recently installed the
> latest (0.7-RC3, all in one w32 package) build at work (I had the latest
> version at home), but somehow none of the code-insight functions work; no
> outline, no tooltips, no syntax checking no autocompletion, etc, etc (in
> installed (eclipse 3.1 / phpeclipse) and I created a new workspace. To be
> exact; I moved (not copied) eclipse 3.1 to a folder eclipse-backup and
> installed 3.2 / pdt in the eclipse folder again so I wouldn't have to
> Gerard / drm
Re: No build of projects (no outline, no completion, no ctrl+click) [message #23397 is a reply to message #23354] Thu, 24 May 2007 08:06 Go to previous messageGo to next message
Originally posted by: seva-eclipse.zend.com
You can do it manually:
1. Create new empty PDT Project.
2. Open .project file.
3. Open .project file of existing PHPEclipse project.
4. Replace Nature & Builders in the .project of existing PHPEclipse project with ones from newly created PDT project.
Done.
On Thu, 24 May 2007 13:19:33 +0300 "Guy Gurfinkel" <guy.g@zend.com> wrote:
GG> You can't migrate phpeclipse project to PDT projects.
GG>
GG>
GG> --
GG> Guy Gurfinkel,
GG> Team Leader, Development Tools
GG> Zend.
GG>
GG> "drm" <drm@melp.nl> wrote in message news:f30s1p$s28$1@build.eclipse.org...
GG> > Hi all,
GG> >
GG> >
GG> > I have been using PDT for a pretty while now, and I recently installed the
GG> > latest (0.7-RC3, all in one w32 package) build at work (I had the latest
GG> > version at home), but somehow none of the code-insight functions work; no
GG> > outline, no tooltips, no syntax checking no autocompletion, etc, etc (in
GG> > PHP files that is, WTP files do work as expected)
GG> >
GG> > I installed it in a separate folder than the previous version i had had
GG> > installed (eclipse 3.1 / phpeclipse) and I created a new workspace. To be
GG> > exact; I moved (not copied) eclipse 3.1 to a folder eclipse-backup and
GG> > installed 3.2 / pdt in the eclipse folder again so I wouldn't have to
GG> > change any shortcuts or whatever. I have no extra plugins installed.
GG> >
GG> > I should also mention that I tested this in projects i imported from the
GG> > previous version of eclipse I had running.
GG> >
GG> > Anyone any idea where I can look to fix this? Especially syntax checking
GG> > is a great miss if you're used to it.
GG> >
GG> >
GG> > Thanks,
GG> > Gerard / drm
GG> >
GG> > PS: Listed version number of the PDT plugins is 0.7.0.v20070401
GG>
Seva Lapsha
[slapsha@dev.eclipse.org]
Zend Eclipse Developer
Re: No build of projects (no outline, no completion, no ctrl+click) [message #23526 is a reply to message #23397] Thu, 24 May 2007 11:02 Go to previous messageGo to next message
> Done.
Thanks Seva, that's great! I feel real stupid not to have thought of
this solution myself... It works like a charm!
I'd expected PDT to fix that file for me when using the "Import existing
projects into workspace", but supposedly there is no way for PDT to know
that the specified project is a php project of some kind?
I'd say this solution should be included in the pdt wiki somewhere, i'm
sure i'm not the only one (not even the only two, together with Chris ;)
Re: No build of projects (no outline, no completion, no ctrl+click) [message #23566 is a reply to message #23397] Fri, 25 May 2007 04:22 Go to previous message
I also put that together as a small howto on my blog some time ago:
http://www.ingo-renner.com/index.php?id=1&tx_ttnews[tt_news]=100&cHash=19eacfea5c
Ingo
Previous Topic:Include path issue
Next Topic:running the builder/scanner depending on system load
Current Time: Thu Jul 03 14:57:13 EDT 2025
Powered by FUDForum. Page generated in 0.03242 seconds
