Xtext 0.7.0M3: Couldn't find resource on classpath - bug? [message #23131] |
Sat, 15 November 2008 11:04  |
I installed Xtext 0.7.0M3, created a project, generated the project
contents with the grammar generator class, ran the UI plugin as an Eclipse
Application, and when I opened a DSL file of mine with the editor, I got
the following error:
Could not open the editor:
org.eclipse.xtext.resource.ClasspathUriResolutionException:
java.lang.IllegalStateException: Couldn't find resource on classpath. URI
was 'classpath:/org/lilypond/LilyPond.ecore#/'
<stack trace>
Strangely, if I deploy the plugin to my Eclipse installation, it works
fine. But I want to be able to run the DSL editor in an RCP app too.
Did this occur to someone else also? Should I submit a bug on this?
Re: Xtext 0.7.0M3: Couldn't find resource on classpath - bug? [message #23367 is a reply to message #23131] |
Wed, 19 November 2008 19:28  |
Hi Dennis,
yes, please submit a bugzilla.
Would be helpful if you could provide a small example project (or at
least the grammar you used) so that we can reproduce the described behavior.
thanks,
Sven
> Eclipse Application, and when I opened a DSL file of mine with the
> editor, I got the following error:
> URI was 'classpath:/org/lilypond/LilyPond.ecore#/'
> <stack trace>
FUDForum. Page generated in 0.16026 seconds
