Home » Archived » BIRT » Programmatically check if emitter is installed?
Programmatically check if emitter is installed? [message #236037] Fri, 20 April 2007 16:55 Go to next message
Originally posted by: dan.dan.com
Hi all,
Any one know of a way to tell whether an emitter (such as the pdf emitter)
is installed programmatically? In other words, I'd like to detect the
emitter is not there and give a friendly message back if it's not there.
Instead of trying to generate the report and getting this exception back:
EngineException: org.eclipse.birt.report.engine.api.EngineException: Report
engine fails to create extension to handle this request.
I'd like to not just catch the exception because from the message, it looks
like it could mean other errors too, not just that the emitter is not found.
Thank you for the help, Dan
Re: Programmatically check if emitter is installed? [message #236154 is a reply to message #236037] Sun, 22 April 2007 13:51 Go to previous messageGo to next message
You could use the plugin registry to see what plugins implement the
org.eclipse.birt.report.engine.emitters extension point, but this will
not cover the case for PDF because it can fail because of a missing
iText lib directory. Hopefully this will not be an issue when 2.2 is
released. It should could include iText.
Jason
dan wrote:
> Hi all,
Re: Programmatically check if emitter is installed? [message #236405 is a reply to message #236154] Mon, 23 April 2007 16:46 Go to previous message
BTW if you are using the engine api you can use the follows methods to
get info on the available emitters.
String[] eo = engine.getSupportedFormats();
EmitterInfo[] ei = engine.getEmitterInfo();
Jason
> Jason
> dan wrote:
>> Hi all,
>> emitter) is installed programmatically? In other words, I'd like to
>> detect the emitter is not there and give a friendly message back if
>> it's not there. Instead of trying to generate the report and getting
>> Report engine fails to create extension to handle this request.
>> looks like it could mean other errors too, not just that the emitter
>> is not found.
Previous Topic:xls emmiter problems
Next Topic:Which output formats are supported?
Current Time: Tue Jul 22 00:53:34 EDT 2025
Powered by FUDForum. Page generated in 1.03120 seconds
