Home » Language IDEs » C / C++ IDE (CDT) » Project Explorer not sorting folders
Project Explorer not sorting folders [message #235792] Tue, 14 July 2009 12:51 Go to next message
Not sure if it is just my setup of Eclipse but I have found that the
Project Explorer isn't sorting folders above files. As such you have a
mashup of folders and files within the list. Using Eclipse 3.5 with CDT 6.0.
Anyone else noticing this issue?
Shawn Clark
Re: Project Explorer not sorting folders [message #235800 is a reply to message #235792] Tue, 14 July 2009 15:07 Go to previous messageGo to next message
Yeah, this is well-known issue... See
https://bugs.eclipse.org/bugs/show_bug.cgi?id=281400 and
https://bugs.eclipse.org/bugs/show_bug.cgi?id=273660.
As a workaround you can disable Java Elements in the Customize
View/Content dialog (pointed down triangle in upper-left corner of Project
Explorer view). If you really need Java Elements disable Resources.
Andrew
Re: Project Explorer not sorting folders [message #235806 is a reply to message #235792] Tue, 14 July 2009 15:09 Go to previous messageGo to next message
Originally posted by: andre.bossert.gmail.com
sorting is broken in Eclipse 3.5 if you have JDT and CDT installed :(
see:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=270103
Andre
Shawn Clark schrieb:
> 6.0.
> Shawn Clark
Re: Project Explorer not sorting folders [message #235812 is a reply to message #235800] Tue, 14 July 2009 15:10 Go to previous messageGo to next message
Doh, upper-right corner.
Re: Project Explorer not sorting folders [message #235818 is a reply to message #235800] Tue, 14 July 2009 16:14 Go to previous message
>> CDT 6.0.
> Project Explorer view). If you really need Java Elements disable Resources.
> Andrew
Thanks for the quick reply. That works as I am not using the Java
Elements right now anyways. :)
Shawn Clark
Previous Topic:Eclipse CDT and uClibc toolchain for MIPS
Next Topic:Post build listener for build automatically.
Current Time: Sun Jul 13 12:42:54 EDT 2025
Powered by FUDForum. Page generated in 0.03989 seconds
