[tycho] mvn package and NullPointerException [message #23071] |
Fri, 13 March 2009 16:00  |
I just tried tycho with the last DEV build.
I want to build a product based on a feature.
I managed to generate pom.xml for my plugin and my feature with tycho.
Now I tried to generate the product but it failed :
C:\PROD\WorkspacesEclipse\TestMaven>c:\prod\tycho\bin\mvn
-Dtycho.targetPlatform=c:\prod\eclipse64
package -e
+ Error stacktraces are turned on.
[INFO] Build target platform tycho.targetPlatform=c:\prod\eclipse64
.. This overrides target platform specified in pom.xml files, if any.
[WARNING] Dependency at location
c:\prod\eclipse64\plugins\org.eclipse.ui.workbench.compatibi lity_3.
2.0.I20080509-2000 can not be represented in Maven model and will not be
visible to non-OSGi aware M
aven plugins
c:\prod\eclipse64\plugins\org.eclipse.core.runtime.compatibi lity.re
gistry_3.2.200.v20080610 can not be represented in Maven model and will
not be visible to non-OSGi a
ware Maven plugins
[INFO] Scanning for projects...
[INFO] Reactor build order:
[INFO] Unnamed - tycho.demo:TestMaven:pom:0.0.1-SNAPSHOT
[INFO] Unnamed -
tycho.demo:com.nbn.tutorial.rcp.withtycho:eclipse-plugin:1.0 .0
[INFO] Unnamed - tycho.demo:withmaven.feature:eclipse-feature:1.0.0
[INFO]
[INFO] Building Unnamed - tycho.demo:TestMaven:pom:0.0.1-SNAPSHOT
[INFO]
[INFO] Id: tycho.demo:TestMaven:pom:0.0.1-SNAPSHOT
[INFO] task-segment: [package]
[INFO]
[INFO] [site:attach-descriptor]
[INFO]
[INFO]
[INFO] Id: tycho.demo:com.nbn.tutorial.rcp.withtycho:eclipse-plugin:1.0 .0
[INFO]
[INFO] [osgi-packaging:build-qualifier]
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [osgi-compiler:compile]
[INFO] Using compile source roots from build.properties
[INFO] Nothing to compile - all classes are up to date
[INFO] [resources:testResources]
[INFO] [osgi-packaging:package-plugin]
[INFO] Building jar:
C:\PROD\WorkspacesEclipse\TestMaven\com.nbn.tutorial.rcp.wit htycho\target\com.n
bn.tutorial.rcp.withtycho-1.0.0.jar
[INFO] [osgi-packaging:product-export]
constituent[0]:
file:/c:/PROD/tycho/bin/../tycho/org.eclipse.osgi-3.4.0.v200 80605-1900.jar
constituent[1]:
file:/c:/PROD/tycho/bin/../tycho/tycho-osgi-components-0.3.0 -DEV-1819.jar
constituent[2]: file:/c:/PROD/tycho/bin/../lib/aspectjrt-1.5.3.jar
constituent[3]: file:/c:/PROD/tycho/bin/../lib/commons-cli-1.0.jar
constituent[4]: file:/c:/PROD/tycho/bin/../lib/commons-logging-api-1.1.jar
constituent[5]:
file:/c:/PROD/tycho/bin/../lib/doxia-sink-api-1.0-alpha-9.ja r
constituent[6]: file:/c:/PROD/tycho/bin/../lib/jsch-0.1.38.jar
constituent[7]: file:/c:/PROD/tycho/bin/../lib/log4j-1.2.12.jar
constituent[8]:
file:/c:/PROD/tycho/bin/../lib/maven-artifact-3.0-alpha-2-TY CHO-695719.jar
constituent[9]:
file:/c:/PROD/tycho/bin/../lib/maven-core-3.0-TYCHO-698080.j ar
constituent[10]:
file:/c:/PROD/tycho/bin/../lib/maven-distribution-3.0-TYCHO- 698080.jar
constituent[11]:
file:/c:/PROD/tycho/bin/../lib/maven-embedder-3.0-TYCHO-6980 80.jar
constituent[12]:
file:/c:/PROD/tycho/bin/../lib/maven-lifecycle-3.0-TYCHO-698 080.jar
constituent[13]:
file:/c:/PROD/tycho/bin/../lib/maven-model-3.0-TYCHO-698080. jar
constituent[14]:
file:/c:/PROD/tycho/bin/../lib/maven-plugin-api-3.0-TYCHO-69 8080.jar
constituent[15]:
file:/c:/PROD/tycho/bin/../lib/maven-profile-3.0-TYCHO-69808 0.jar
constituent[16]:
file:/c:/PROD/tycho/bin/../lib/maven-project-3.0-TYCHO-69808 0.jar
constituent[17]:
file:/c:/PROD/tycho/bin/../lib/maven-reporting-api-3.0-TYCHO -698080.jar
constituent[18]:
file:/c:/PROD/tycho/bin/../lib/maven-shared-model-1.0-TYCHO- 698080.jar
constituent[19]:
file:/c:/PROD/tycho/bin/../lib/maven-toolchain-3.0-TYCHO-698 080.jar
constituent[20]:
file:/c:/PROD/tycho/bin/../lib/maven-workspace-3.0-TYCHO-698 080.jar
constituent[21]: file:/c:/PROD/tycho/bin/../lib/nekohtml-1.9.6.2.jar
constituent[22]:
file:/c:/PROD/tycho/bin/../lib/plexus-container-default-1.0- alpha-48.jar
constituent[23]:
file:/c:/PROD/tycho/bin/../lib/plexus-interactivity-api-1.0- alpha-6.jar
constituent[24]: file:/c:/PROD/tycho/bin/../lib/plexus-interpolation-1.1.jar
constituent[25]: file:/c:/PROD/tycho/bin/../lib/plexus-utils-1.5.5.jar
constituent[26]: file:/c:/PROD/tycho/bin/../lib/stax-api-1.0-2.jar
constituent[27]: file:/c:/PROD/tycho/bin/../lib/stax-api-1.0.1.jar
constituent[28]: file:/c:/PROD/tycho/bin/../lib/wagon-file-1.0-beta-4.jar
constituent[29]:
file:/c:/PROD/tycho/bin/../lib/wagon-http-lightweight-1.0-be ta-4.jar
constituent[30]:
file:/c:/PROD/tycho/bin/../lib/wagon-http-shared-1.0-beta-4. jar
constituent[31]:
file:/c:/PROD/tycho/bin/../lib/wagon-provider-api-1.0-beta-4 .jar
constituent[32]: file:/c:/PROD/tycho/bin/../lib/wagon-ssh-1.0-beta-4.jar
constituent[33]:
file:/c:/PROD/tycho/bin/../lib/wagon-ssh-common-1.0-beta-4.j ar
constituent[34]:
file:/c:/PROD/tycho/bin/../lib/wagon-ssh-external-1.0-beta-4 .jar
constituent[35]: file:/c:/PROD/tycho/bin/../lib/wstx-asl-3.2.6.jar
constituent[36]: file:/c:/PROD/tycho/bin/../lib/xbean-reflect-3.4.jar
constituent[37]: file:/c:/PROD/tycho/bin/../lib/xercesMinimal-1.9.6.2.jar
at de.schlichtherle.io.File.<init>(File.java:427)
at de.schlichtherle.io.File.<init>(File.java:406)
org.codehaus.tycho.eclipsepackaging.ProductExportMojo.copyFe ature(ProductExportMojo.java:
292)
org.codehaus.tycho.eclipsepackaging.ProductExportMojo.copyFe atures(ProductExportMojo.java
:267)
org.codehaus.tycho.eclipsepackaging.ProductExportMojo.execut e(ProductExportMojo.java:116)
org.apache.maven.plugin.DefaultPluginManager.executeMojo(Def aultPluginManager.java:623)
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeG oalAndHandleFailures(DefaultL
ifecycleExecutor.java:521)
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeT askSegmentForProject(DefaultL
ifecycleExecutor.java:288)
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeT askSegments(DefaultLifecycleE
xecutor.java:214)
org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute( DefaultLifecycleExecutor.java
:172)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:218)
org.apache.maven.embedder.MavenEmbedder.execute(MavenEmbedde r.java:899)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:176)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:63)
org.codehaus.plexus.classworlds.launcher.Launcher.launchEnha nced(Launcher.java:289)
org.codehaus.plexus.classworlds.launcher.Launcher.launch(Lau ncher.java:229)
org.codehaus.plexus.classworlds.launcher.Launcher.mainWithEx itCode(Launcher.java:408)
org.codehaus.plexus.classworlds.launcher.Launcher.main(Launc her.java:351)
at org.codehaus.classworlds.Launcher.main(Launcher.java:31)
Here is the pom.xml for my plugin
<project>
<modelVersion>4.0.0</modelVersion>
<parent>
<artifactId>TestMaven</artifactId>
<groupId>tycho.demo</groupId>
<version>0.0.1-SNAPSHOT</version>
</parent>
<artifactId>com.nbn.tutorial.rcp.withtycho</artifactId>
<version>1.0.0</version>
<packaging>eclipse-plugin</packaging>
<build>
<plugins>
<plugin>
<groupId>org.codehaus.tycho</groupId>
<artifactId>maven-osgi-packaging-plugin</artifactId>
<executions>
<execution>
<phase>package</phase>
<id>product-export</id>
<goals>
<goal>product-export</goal>
</goals>
<configuration>
<productConfigurationFile>withtycho.product</productConfigurationFile >
<!-- replace to your real goal if you didn't use same namming -->
</configuration>
</execution>
</executions>
</plugin>
</plugins>
</build>
</project>
here is for my feature
<project>
<parent>
</parent>
<artifactId>withtycho.feature</artifactId>
<packaging>eclipse-feature</packaging>
</project>
And the parent pom :
<project>
<packaging>pom</packaging>
<modules>
<module>com.nbn.tutorial.rcp.withtycho</module>
<module>withtycho.feature</module>
</modules>
</project>
when I check my target directory I find the product directory but
obviously it's not complete...
I can find my plugin jar too. But not the feature jar.
Any tip or idea ? :)
Nicolas Bihan
Re: [tycho] mvn package and NullPointerException [message #23115 is a reply to message #23071] |
Fri, 13 March 2009 16:33  |
Originally posted by: igor.ifedorenko.com
Documentation is not up-to-date, unfortunately... You need to move
product to a separate maven project with packaging=clipse-application,
otherwise tycho cannot properly order projects. You can find working
example (using during tycho integration tests) here
http://svn.sonatype.org/m2eclipse/tycho/trunk/tycho-its/proj ects/tycho109/feature-rcp/
Also, I opened https://issues.sonatype.org/browse/MNGECLIPSE-1272 to
provide better error message.
Igor
Nicolas Bihan wrote:
> Hello,
> package -e
> aven plugins
> ware Maven plugins
> [INFO] Unnamed -
> [INFO]
> [INFO]
> [INFO]
> [INFO]
> [INFO]
> [INFO]
> constituent[0]:
> constituent[1]:
> constituent[5]:
> constituent[8]:
> constituent[9]:
> constituent[10]:
> constituent[11]:
> constituent[12]:
> constituent[13]:
> constituent[14]:
> constituent[15]:
> constituent[16]:
> constituent[17]:
> constituent[18]:
> constituent[19]:
> constituent[20]:
> constituent[22]:
> constituent[23]:
> constituent[24]:
> constituent[29]:
> constituent[30]:
> constituent[31]:
> constituent[33]:
> constituent[34]:
> java.lang.NullPointerException
> at
> 292)
> at
> :267)
> at
> at
> at
> at
> at
> xecutor.java:214)
> at
> :172)
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> <project>
> <parent>
> </parent>
> <build>
> <plugins>
> <plugin>
> <executions>
> <execution>
> <goals>
> </goals>
> <configuration>
> </configuration>
> </execution>
> </executions>
> </plugin>
> </plugins>
> </build>
> </project>
> <project>
> <parent>
> </parent>
> </project>
> <project>
> <modules>
> </modules>
> </project>
> Nicolas Bihan
FUDForum. Page generated in 0.06948 seconds
