| Importing Packages with Eclipse [message #235601] |
Tue, 27 April 2004 18:20   |
Eclipse User  |
Originally posted by: haatho20.web.de
Hello everybody,
i have the following problem:
I have written a java-Package with lays in the root directory of my eclipse
project. But Eclipse does not recognize it as a package and each time i want
to call a method from some of the classes in the package i get an
errormessage. I included the package properly. When i start the project in
forte (Sun One ... or something like this) it works.
Can anybody help me ?
Thomas
| Re: Importing Packages with Eclipse [message #236442 is a reply to message #235756] |
Thu, 29 April 2004 08:52    |
Eclipse User  |
Originally posted by: jm.nospam.steranka.com
In article <c6nvvh$lik$1@eclipse.org>, Marko.Schulz@gmx.de says...
> In eclipse: Do the directories and .java-Files show up in the Navigator?
> In the package explorer? With what Icons beside them? A filled or a
> shaped "J" in a box? The latter would indicate, that eclipse recognizes
> them as Java-Files but the project isn't set up in a way, that eclipse
> is supposed to compile and use them. Maybe because the project isn't a
> Java project, which is indicated by a little J in the project icon. Or
> the build path isn't set correctly (see the properties of the project
> and there Java Build Path->Source), since - depending e.g. on how you
> created the project - sometimes the sources are expected within a folder
> "src".
Marko, or others,
(Q) Is there a way to take a project that starts out as a "normal" (non-java) project
    and change it to a Java project?
(Q) When you are in a Java project, and say "Create package" com.acme.foo, and
    also say Create Folder com/acme/bar.  What happens differently underneath
    the covers?
(A) My guess is that when you create a folder, the folder is added to the
    "source exclude directories list".  If you add a package this doesn't happen
    and that is the only difference.
Patrick Steranka
> The project the classes are in show no compilation errors (a little X in
> a red box in the package explorer) before you want to call a method
> (which then is shown as anq error, right?)? You want to call the methods
> from classes within the same project?
>  > When i start the project in forte (Sun One ... or something like
> this) it works.
> Yes, that is not surprising. Forte is another Java-IDE, just like
> eclipse can be used as one. What do you expect, if it is correctly
> configured?
> marko
| Re: Importing Packages with Eclipse [message #236932 is a reply to message #236442] |
Thu, 29 April 2004 12:59   |
Eclipse User  |
I would just start a new project and copy the contents over from the
old. But it might (read: on your own risk) also work if you just edit
the File .project and change these lines
	<buildSpec>
	</buildSpec>
	<natures>
	</natures>
to these lines
	<buildSpec>
		<buildCommand>
			<name>org.eclipse.jdt.core.javabuilder</name>
			<arguments>
			</arguments>
		</buildCommand>
	</buildSpec>
	<natures>
		<nature>org.eclipse.jdt.core.javanature</nature>
	</natures>
while eclipse is not running.
FUDForum. Page generated in 0.04511 seconds
