Home » Language IDEs » Java Development Tools (JDT) » JUnit not launching after callisto update
JUnit not launching after callisto update [message #235291] Tue, 29 August 2006 09:53 Go to next message
I just noticed that after installing the callisto release, I am no longer
able to run or debug a JUnit testcase. I don't get any errors in either
the console or the .log file in my .metadata directory. The testcase
context menu is correct - the source file has the Run as JUnit test and
Debug as JUnit test in the menu but the keystroke seems to be ignored or
tossed in the bit-bucket.
I have created a project with just a helloworld type of program, then had
Eclipse create the testcase for me just me verify it wasn't my existing
projects.
Any suggestions on where to look next???
Re: JUnit not launching after callisto update [message #235301 is a reply to message #235291] Tue, 29 August 2006 10:21 Go to previous messageGo to next message
Some additional information - this seems to be related to one of the
workspaces that I am using. I created a new (clean) workspace, then
created the helloworld type program and testcase. In that workspace I can
run/debug the testcase.
Is there any way to verify/check the workspace? Otherwise I guess I have
to rebuild my workspace with all my work projects which I am hoping to not
have to do.
Re: JUnit not launching after callisto update [message #235322 is a reply to message #235301] Tue, 29 August 2006 10:36 Go to previous message
> can run/debug the testcase.
> have to rebuild my workspace with all my work projects which I am hoping
> to not have to do.
You can create a new workspace and the use File>Import...>Existing
projects into workspace ... you can copy them into the new workspace
(thus if it doesn't work, you haven't damaged your current workspace).
Later,
PW
Previous Topic:Setting up JavaDoc with custom tags
Next Topic:parser problem with annotations and array initializers
Current Time: Wed Jul 16 20:01:57 EDT 2025
Powered by FUDForum. Page generated in 0.04731 seconds
