Home » Eclipse Projects » GEF » Get the size of my plugin's view
Get the size of my plugin's view [message #235229] Thu, 07 June 2007 05:14 Go to next message
Originally posted by: malnatij.lu.unisi.ch
Hi, given that every view can be dynamically resized by the user, I would like to know how to get it's size (the x axis is enough).
Any idea?
Re: Get the size of my plugin's view [message #235277 is a reply to message #235229] Thu, 07 June 2007 21:31 Go to previous messageGo to next message
You probably need to get the size of the control that the view uses. There
is a getBounds() method on the control that would give you its size in
pixels.
Alex
Re: Get the size of my plugin's view [message #237558 is a reply to message #235277] Sun, 05 August 2007 15:08 Go to previous messageGo to next message
Hi, I didn't focus on this problem till now, and I'm still wondering how to solve it.
You suggested to get the bounds of the controller, but I don't see any way to get this "controller"... any idea?
I just need to know the actual size of the view that my plug-in creates
Re: Get the size of my plugin's view [message #237583 is a reply to message #237558] Mon, 06 August 2007 02:46 Go to previous messageGo to next message
You shouldn't look for a "contoller" but a Control (an SWT class). Your
view's content is created on a Composite (given to you as a parameter of
the createPartCOntrol method). You just should keep a reference on this
SWT Composite object and asks it when you need : getBounds().
Hope this can help
Manuel
Re: Get the size of my plugin's view [message #237615 is a reply to message #237583] Mon, 06 August 2007 08:56 Go to previous message
Thanks, I did it :) cool
Previous Topic:Using retarget actions from a GEF editor
Next Topic:What should a paste action derive from? (triggering calculateEnabled())
Current Time: Mon May 12 07:42:26 EDT 2025
Powered by FUDForum. Page generated in 0.04996 seconds
