Home » Language IDEs » C / C++ IDE (CDT) » syntax error after including class definition
syntax error after including class definition [message #235038] Mon, 22 June 2009 05:15 Go to next message
I am using eclipse platform Version: 3.4.2 Build id: M20090211-1700
together with cdt 5.0.2 and gcc compiler.
I define a class "PrintUtil.h" and build the project. Everything is ok.
I include the header file of the class in main program and build the
project. Now I get syntax error in the header file of the class
..\src\PrintUtil.h:11: error: syntax error before "PrintUtil"
..\src\PrintUtil.h:11: error: syntax error before '{' token
Hier is the code for the class header file "PrintUtil.h"
#ifndef PRINTUTIL_H_
#define PRINTUTIL_H_
class PrintUtil {
public:
void getApplicationInformation()
printf("rns version 2.1");
#endif /* PRINTUTIL_H_ */
Re: syntax error after including class definition [message #235063 is a reply to message #235038] Mon, 22 June 2009 15:49 Go to previous messageGo to next message
You should learn C++, its a compiler issue ;)
alu schrieb:
> class PrintUtil {
> public:
Re: syntax error after including class definition [message #837286 is a reply to message #235063] Thu, 05 April 2012 09:34 Go to previous message
This answer is really unhelpful. Just ran into the same issue above.
Previous Topic:Expressions not always updating
Next Topic:How to set project defaults
Current Time: Fri Nov 21 09:39:17 EST 2025
Powered by FUDForum. Page generated in 0.03309 seconds
