Home » Language IDEs » Java Development Tools (JDT) » JDT is not aware of classes compiled by another compiler
JDT is not aware of classes compiled by another compiler [message #234897] Tue, 22 August 2006 17:04 Go to next message
Originally posted by: a.shneyderman.gmail.com
I have a builder and that calls upon a groovy compiler. The compiler is
spitting out .class files. I would like my JDT to be aware of the newly
produced .class files. How do I do that. Just placing .class files into the
output directory does not appear sufficient.
I have been looking for some similar code samples but unable to find any.
Anyone has an idea?
Alex.
Re: JDT is not aware of classes compiled by another compiler [message #234907 is a reply to message #234897] Tue, 22 August 2006 18:11 Go to previous messageGo to next message
> Anyone has an idea?
> Alex.
You have to refresh the directory which contains the class files to make
eclipse aware of the new files. See IResource.refreshLocal().
Re: JDT is not aware of classes compiled by another compiler [message #235031 is a reply to message #234907] Wed, 23 August 2006 16:40 Go to previous messageGo to next message
Let me clarify. The java editor does not see the newly compiled file. The
editor sohws that the class is not available. When I launch Eclipse
complains but allows me to proceed with the launch anyway. It runs okay, but
the editor and codeassist are completely anaware of the class.
I am not expecting much from editor but I would think that something that it
produces for the classes from the jars would suffice.
Any more ideas?
Alex.
Re: JDT is not aware of classes compiled by another compiler [message #235043 is a reply to message #235031] Wed, 23 August 2006 18:29 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
I don't think the JDT Java editor really look at the output directory.
It looks at the source folders, jars, and class folders. That is because
the output directory is for generated output that can be wiped, erased,
and recreated at any time.
Does your "groovy compiler" use java source, or does it use some other
kind of source that generates only a java .class file?
Rich Kulp
Re: JDT is not aware of classes compiled by another compiler [message #235050 is a reply to message #235043] Wed, 23 August 2006 21:56 Go to previous messageGo to next message
That's a real pitty. There are a few tools I know that take a non java
source
and produce the .class files. One example comes to mind is AspectJ.
I just checked how AspectJ deals with this and found out that it does not.
So say
you write an advice A. AJDT will produce A.class file in your output dir.
Then in
your java one could do A.aspectOf(). When I use java editor red markers pop
up
all over. In AJ editor auto-completion does not work but at least no
complaints from
the editor.
I wonder if there is a way to make java editor understand the situation
somehow.
nope groovy source is a groovy source (groovy.codehaus.org), but groovyc
will
produce .class files. no intermediate .java are produced.
Alex.
Re: JDT is not aware of classes compiled by another compiler [message #235076 is a reply to message #235050] Thu, 24 August 2006 06:51 Go to previous messageGo to next message
--------------010402080401020400040809
Alex,
The expectation is that there will be a builder that's hooked up to
produce these results for all the various tools that produce build
results. So at the beginning of the build, the bin directory can be
flushed and then the builders will populate it during the build. I'm
pretty sure AJDT does this too. I suspect that your reasoning about the
error markers implying AJDT has this problem too is flawed. I expect
that what you see is simply a reflection of the fact that Aspect source
code is not valid Java syntax and needs to be interpreted by an Aspect
aware processor/editor. Ask yourself this, could AJDT function at all
without having solved this problem?
How about compiling to a folder other than bin and putting that folder
on the classpath?
> source
> So say
> Then in
> up
> complaints from
> the editor.
> somehow.
> will
> Alex.
<html>
<head>
</head>
Alex,<br>
<br>
results.&nbsp; So at the beginning of the build, the bin directory can be
flushed and then the builders will populate it during the build.&nbsp; I'm
pretty sure AJDT does this too.&nbsp; I suspect that your reasoning about
the error markers implying AJDT has this problem too is flawed.&nbsp; I
expect that what you see is simply a reflection of the fact that Aspect
source code is not valid Java syntax and needs to be interpreted by an
Aspect aware processor/editor.&nbsp; Ask yourself this, could AJDT function
at all without having solved this problem?&nbsp; <br>
<br>
on the classpath?<br>
<br>
<br>
<blockquote cite="midecj0vr$usc$1@utils.eclipse.org" type="cite">
<blockquote type="cite">
<pre wrap="">I don't think the JDT Java editor really look at the output directory.
</pre>
</blockquote>
<pre wrap=""><!---->
source
So say
Then in
up
complaints from
the editor.
somehow.
</pre>
<pre wrap="">Does your "groovy compiler" use java source, or does it use some other
</pre>
</blockquote>
will
Alex.
</pre>
</blockquote>
<br>
</body>
</html>
--------------010402080401020400040809--
Re: JDT is not aware of classes compiled by another compiler [message #235083 is a reply to message #235076] Thu, 24 August 2006 09:37 Go to previous messageGo to next message
Ed, I think we are talking apples and oranges here,
or maybe I was not clear in my explanations.
Here is a second try:
I have an ApsectJ advice that looks like this:
public aspect ErrorCodeResolvingAspect {
protected pointcut errorResolvableJoinPoints () ..... ;
after () throwing (Throwable e) : errorResolvableJoinPoints () {
assuming that the aspect above is syntactically correct AJDT will
produce .class file in hte output directory. If I create .java file
and open it with Java editor, I can say something like
ErrorCodeResolvingAspect.aspectOf() in my java source - no AJ source
involved at this point - since aspectOf is a static method that aj compiler
generates for me and ErrorCodeResolvingAspect is valid bytecode.
In Java editor I see a bunch of markers saying that the
editor does not know anything about class ErrorCodeResolvingAspect. If I
run the code that contains the code that is marked as invalid by Java
editor it runs fine. Markers are not cleared even after I run the code.
So the java compiler knows about the class that has no Java source
behind it, the launcher finds it also but Java editor does not.
When I open the same java file with AJ editor (which is possible since
java source is a subset of aj source), the only thing that is different
about AJ editor is that it does not mark the statements with error markers.
The code assist does not work in aj either, so is auto import of classes.
> hooked up to produce these results for all the various tools
> that produce build results. So at the beginning of
the problem it seems that the builder has no way of notifying javamodel of
newly
produced classes that have no java source behind it. or maybe there is? I
would
love to know how.
I am pretty sure it is possible since java editor seems to be able to
extract
stuff from .jar files about its contained classes.
> the build, the bin directory can be flushed and then the
> builders will populate it during the build. I'm pretty sure
I meant that java editor has problems while dealing with classes produced by
AJDT.
once again I did not try to view aj file with java editor, just java source
that uses classes
produced by AspectJ
> that folder on the classpath?
I tried that but that does not work either. I compiled all of my groovy
files in .groovy dir and placed
that directory on the classpath. Frankly, I do not see how that is different
from what is done now.
Alex.
Re: JDT is not aware of classes compiled by another compiler [message #235090 is a reply to message #235083] Thu, 24 August 2006 10:07 Go to previous messageGo to next message
You should be using a separate class folder on your buildpath instead as
the output of the groovy compiler. The groovy compiler builder should
manage that class folder all on its own, clearing out derived class
files as needed, like the real compiler does. The groovy compiler will
need to use either IFile.setContents() or IFile.refreshLocal() to allow
JDT to know that there is a new/changed/deleted file out there.
JDT Java editor DOES look at the classfolders that are defined to the
build path and the java editor will know about the compiled class. It
won't be able to open the class itself since there is no java source,
but the compiler will work.
The reason launching works is because it doesn't look at source, it
simply puts the output directory onto the new JVM's classpath. Just like
any other class folder.
Rich Kulp
Re: JDT is not aware of classes compiled by another compiler [message #235098 is a reply to message #235083] Thu, 24 August 2006 10:12 Go to previous messageGo to next message
--------------060705000207030008050800
Alex,
Well, I'll have to leave it to the experts to address (they seem quiet
these days), because I'm certainly no expert and I'm out of theories and
suggestions. Haven't other groovy users encountered this and solved
it? Maybe folks typically keep the groovy stuff in a separate project
and that way works?
> newly
> would
> love to know how.
> extract
> AJDT.
> that uses classes
> produced by AspectJ
> Alex.
<html>
<head>
</head>
Alex,<br>
<br>
and suggestions.&nbsp; Haven't other groovy users encountered this and
solved it?&nbsp; Maybe folks typically keep the groovy stuff in a separate
project and that way works?<br>
<br>
<br>
<blockquote cite="midecka3h$r0q$1@utils.eclipse.org" type="cite">
<pre wrap="">Ed, I think we are talking apples and oranges here,
</pre>
<pre wrap="">The expectation is that there will be a builder that's
</pre>
</blockquote>
newly
would
love to know how.
extract
</pre>
<pre wrap="">the build, the bin directory can be flushed and then the
</pre>
</blockquote>
AJDT.
</pre>
<pre wrap="">source code is not valid Java syntax and needs to be interpreted by an
</pre>
</blockquote>
that uses classes
produced by AspectJ
</pre>
<pre wrap="">How about compiling to a folder other than bin and putting
</pre>
</blockquote>
Alex.
</pre>
</blockquote>
<br>
</body>
</html>
--------------060705000207030008050800--
Re: JDT is not aware of classes compiled by another compiler [message #235168 is a reply to message #235090] Fri, 25 August 2006 07:06 Go to previous messageGo to next message
Thanks, Rich!
> manage that class folder all on its own, clearing out derived class files
> as needed, like the real compiler does. The groovy compiler will need to
> use either IFile.setContents() or IFile.refreshLocal() to allow JDT to
this approach works but has its limitations. For example, navigation between
groovy code and java code is problematic. One the code is opened by
javaeditor and
two it is not editable.
While it is a good progres, the solution seems to be one-sided.
Any more ideas?
Re: JDT is not aware of classes compiled by another compiler [message #235205 is a reply to message #235168] Sat, 26 August 2006 17:55 Go to previous message
> Any more ideas?
I will suggest something else.
Why don't you add a class folder on the classpath that would be the
output of the first builder. At the end of the first builder, you should
call a refresh on this class folder and this would make the .class
files from the first builder visible for the second builder.
I haven't tried, but you might want to give it a try.
Olivier
Previous Topic:plugin for existing menu items
Next Topic:source level errors when building jdt module in eclipse 3.2 on windows
Current Time: Thu Nov 13 13:53:27 EST 2025
Powered by FUDForum. Page generated in 0.04813 seconds
