Home » Archived » BIRT » beforeDrawLegendEntry(..) should provide the LegendRenderHint
beforeDrawLegendEntry(..) should provide the LegendRenderHint [message #234508] Fri, 13 April 2007 10:42 Go to next message
the beforeDrawLegendEntry method in IChartEventHandler only gives access
to the label and the external context. To be consistent with the rest of
the api, I think we should also provide the LegendRenderHint object to
provide greater flexiblity for working with legend entries
Re: beforeDrawLegendEntry(..) should provide the LegendRenderHint [message #234927 is a reply to message #234508] Tue, 17 April 2007 02:55 Go to previous message
This method is deprecated, use beforeDrawLegendItem(
LegendEntryRenderingHints, Bounds, IChartScriptContext) instead.
David
"Raheel Ashraf" <rashraf@ca.ibm.com> wrote in message
news:324449387bfac5c43d54e431a3bc1ca7$1@www.eclipse.org...
Previous Topic:update a script of datasource using a library
Next Topic:Expandable way to list options in report parameters
Current Time: Fri Nov 07 03:57:02 EST 2025
Powered by FUDForum. Page generated in 0.03052 seconds
