Eclipse 3.4 Headless Build Issues [message #22966] |
Mon, 22 September 2008 12:54  |
I've got a small RCP Plug-in application that I can perform a headless
build on using Eclipse 3.3 with the Delta-Pack installed (the target is a
Win32, Win32, x86 platform).
A) When I migrate to 3.4, the build script executes, but does not generate
an exe within the deployment zip file.
B) When I additionally install the Delta-Pack for 3.4, the build script
fails with the following error. The confusing part is that I'm specifying
(in build.properties) that the version of the Equinox.launcher plugin is
1.0.100.v20080509-1800. I've verified that this exists in my eclipse
environment.
I've included the relevant portion of my Build output below.
Can anyone shed some light on my situation
and whether I do need the
Delta-Pack.
Thanks!!!
Tom
<Clip, Clip>
[java] [eclipse.buildScript] Some inter-plug-in dependencies have not
been satisfied.
[java] [eclipse.buildScript] Bundle
org.eclipse.core.filesystem.win32.x86:
[java] [eclipse.buildScript] Bundle org.eclipse.core.net.win32.x86:
org.eclipse.equinox.launcher.win32.win32.x86:
org.eclipse.equinox.security.win32.x86:
[java] [eclipse.buildScript] Bundle org.eclipse.swt.win32.win32.x86:
[java] BUILD FAILED
[java]
C:\StsEnvironment\Software\eclipse\plugins\org.eclipse.pde.b uild_3.4.0.v20080604\scripts\productBuild\productBuild.xml:2 8:
The following error occurred while executing this line:
[java]
C:\StsEnvironment\Software\eclipse\plugins\org.eclipse.pde.b uild_3.4.0.v20080604\scripts\build.xml:64:
[java]
C:\StsEnvironment\Software\eclipse\plugins\org.eclipse.pde.b uild_3.4.0.v20080604\templates\headless-build\customTargets. xml:12:
[java]
C:\StsEnvironment\Software\eclipse\plugins\org.eclipse.pde.b uild_3.4.0.v20080604\scripts\productBuild\allElements.xml:9:
[java]
C:\StsEnvironment\Software\eclipse\plugins\org.eclipse.pde.b uild_3.4.0.v20080604\scripts\genericTargets.xml:113:
Unable to find plug-in: org.eclipse.equinox.launcher_1.0.100.v20080501.
Please check the error log for more details.
[java] Total time: 5 seconds
BUILD FAILED
C:\IssDevelopment\svn\branches\Admin-Rcp\IssCodeline\ca.gc.c i.sts.admin.SecureSystemsAdminApplication.build\build.xml:81 :
C:\IssDevelopment\svn\branches\Admin-Rcp\IssCodeline\ca.gc.c i.sts.admin.SecureSystemsAdminApplication.build\build.xml:85 :
C:\IssDevelopment\svn\branches\Admin-Rcp\IssCodeline\ca.gc.c i.sts.admin.SecureSystemsAdminApplication.build\build.xml:64 :
Java returned: 13
Re: Eclipse 3.4 Headless Build Issues [message #24313 is a reply to message #22966] |
Thu, 25 September 2008 16:14  |
The executables are in the feature org.eclipse.equinox.executable which
is part of the delta pack. Therefore, if you don't have the deltapack,
you don't have executables.
The product build automatically includes this executable feature in
order to pick up the executables and the launcher bundle & fragment.
Your error seems to come from a mismatch between what version of the
launcher the executable feature is asking for and what version is
actually in the build.
If there are multiple versions of the launcher in the target, then it
may be that the higher version is selected and preventing the feature
from finding the version it wants.
-Andrew
> a Win32, Win32, x86 platform).
> generate an exe within the deployment zip file.
> specifying (in build.properties) that the version of the
> Equinox.launcher plugin is 1.0.100.v20080509-1800. I've verified that
> this exists in my eclipse environment.
> Can anyone shed some light on my situation�and whether I do need the
> Delta-Pack.
> Thanks!!!
> Tom
> <Clip, Clip>
> not been satisfied.
> [java] BUILD FAILED
> [java]
> [java]
> [java]
> [java]
> [java]
> BUILD FAILED
> Java returned: 13
Re: Eclipse 3.4 Headless Build Issues [message #581653 is a reply to message #22966] |
-Andrew
> Delta-Pack.
> Thanks!!!
> Tom
> <Clip, Clip>
> not been satisfied.
> [java] BUILD FAILED
> [java]
> [java]
> [java]
> [java]
> [java]
> BUILD FAILED
> Java returned: 13
FUDForum. Page generated in 0.04413 seconds
