Home » Eclipse Projects » Mylyn » Removing a Task Repository
Removing a Task Repository [message #22949] Sun, 19 August 2007 15:45 Go to next message
Hi!
Is it possible to remove a Task Repository in Mylyn 2.0? I'm running the released version, not the dev build.
I find an option for adding new Task Repositories, but not removing old once.
btw: when trying to upgrade to the latest dev builds after setting update sites as described at http://www.eclipse.org/mylyn/downloads/builds.php I get the following warning in eclipse when selecting Mylyn:
Subclipse Mylar Integration (1.0.1) requires plug-in "org.eclipse.mylar.tasks.core (0.9.2)", or later version.
-Kaj :)
Re: Removing a Task Repository [message #23351 is a reply to message #22949] Tue, 21 August 2007 05:33 Go to previous message
Ofcource... :)
Just solved this by disable Subclipse Mylar Integration (1.0.1)
-Kaj :)
Re: Removing a Task Repository [message #578019 is a reply to message #22949] Tue, 21 August 2007 05:33 Go to previous message
Ofcource... :)
-Kaj :)
Previous Topic:Task context after crashes
Next Topic:Default Eclipse 3.3/Europa redistribution and org.eclipse.mylyn.team.ui
Current Time: Fri Nov 14 03:41:23 EST 2025
Powered by FUDForum. Page generated in 0.03460 seconds
