Home » Eclipse Projects » Eclipse Platform » org.eclipse.ui.parts.editors missing in v2.1
org.eclipse.ui.parts.editors missing in v2.1 [message #22943] Tue, 29 April 2003 14:35 Go to next message
Originally posted by: sinleeh.hotmail.com
Dear all,
I was trying to use the extension org.eclipse.ui.parts.editors to define a
new editor as I did in RC3 but eclipse kept on telling me that that
extension does not exist. I apreciate any clues to why this is the case.
Thanking you in advance and best regards,
Sinleeh
Re: org.eclipse.ui.parts.editors missing in v2.1 [message #23228 is a reply to message #22943] Tue, 29 April 2003 15:31 Go to previous messageGo to next message
Originally posted by: simon.ibm.oti.lab
The extension point is org.eclipse.ui.editors (there is no .parts in the
extension point name). It's been like that since release 1.0
Simon :-)
"sinleeh" <sinleeh@hotmail.com> wrote in message
news:b8mgkr$i4d$1@rogue.oti.com...
> Dear all,
> Sinleeh
Re: org.eclipse.ui.parts.editors missing in v2.1 [message #23850 is a reply to message #23228] Wed, 30 April 2003 10:20 Go to previous messageGo to next message
Dear Simon et.al.,
Thanks for the answer. It was a typo on my part. I did tried it with
org.eclipse.ui.editors. The funny thing is, eventhough I am using version
2.1, I cannot find any extension point org.eclipse.ui.editors to connect
my editor to.
In fact, when compared to RC3a on Windows, when editing the plugin.xml
file using the provided editor, under the tag "extensions" clicking
"Add"->Generic Wizard->Schema-based extension->Next does not show up any
extension points.
Also, if I were on the Dependencies page and click "Add" on the section
"required plugin", the screen which is used to be populated with a lot of
plugin is just empty on v2.1.
I downloaded the SDK version. This happens on both solaris8 and linux
version, where did I go wrong?
Thanking you in advance.
sinleeh
> Simon :-)
> > Dear all,
> > Sinleeh
Re: org.eclipse.ui.parts.editors missing in v2.1 [message #24208 is a reply to message #23850] Wed, 30 April 2003 11:31 Go to previous messageGo to next message
Open a problem report against the PDE team in bugzilla
Simon :-)
news:b8om3e$35p$1@rogue.oti.com...
> Dear Simon et.al.,
> my editor to.
> extension points.
> Best regards,
> sinleeh
> > Simon :-)
> > > Dear all,
define a
case.
> > > Sinleeh
Re: org.eclipse.ui.parts.editors missing in v2.1 [message #24290 is a reply to message #24208] Wed, 30 April 2003 11:58 Go to previous messageGo to next message
Dear Simon,
I'm not actually certain it is a bug, now that I had solved the mistery:
It appears that I was actually in Java Development Perspective. After
switching to Plug-in Development Perspective, I started a new plug-in
project from scratch and perform the same steps to add a new extensions, a
warning was displayed saying that Extension were by default disabled, and
by clicking OK they will all be enabled. After clicking OK everything is
OK, including dependencies pages.
This makes me think that it is the intention of the PDE development team
of not displaying available extension points when the user first startup.
To me, the problem is that this changes in behaviour from previous edition
is not documented clearly. Do you still think it is worth writing a
problem report?
Once again, thank you for all your assistance. It is greatly appreciated.
Sinleeh
> Simon :-)
> > Dear Simon et.al.,
> > my editor to.
> > extension points.
> > Best regards,
> > sinleeh
> > > Simon :-)
> > > > Dear all,
> define a
> case.
> > > > Sinleeh
Re: org.eclipse.ui.parts.editors missing in v2.1 [message #24812 is a reply to message #24290] Wed, 30 April 2003 14:31 Go to previous messageGo to next message
Yes, open a problem report to PDE so they can explain what is happening.
Maybe there is something else wrong that is causing the extension point not
to be visible at first.
Simon :-)
news:b8orrk$8si$1@rogue.oti.com...
> Dear Simon,
> problem report?
> Best regards,
> Sinleeh
> > Simon :-)
> > > Dear Simon et.al.,
version
connect
> > > my editor to.
any
> > > extension points.
section
of
> > > Best regards,
> > > sinleeh
the
> > > > Simon :-)
> > > > > Dear all,
> > define a
that
> > case.
> > > > > Sinleeh
Re: org.eclipse.ui.parts.editors missing in v2.1 [message #25572 is a reply to message #24812] Thu, 01 May 2003 10:11 Go to previous messageGo to next message
Dear Simon,
I will do it as soon as I gather more information about this on the other
platforms that I am testing eclipse on (Win32, Debian Linux and Solaris8).
Many thanks,
sinleeh. ;)
> Simon :-)
> > Dear Simon,
> > problem report?
> > Best regards,
> > Sinleeh
> > > Simon :-)
> > > > Dear Simon et.al.,
> version
> connect
> > > > my editor to.
> any
> > > > extension points.
> section
> of
> > > > Best regards,
> > > > sinleeh
> the
> > > > > Simon :-)
> > > > > > Dear all,
> > > define a
> that
> > > case.
> > > > > > Sinleeh
Re: org.eclipse.ui.parts.editors missing in v2.1 [message #26128 is a reply to message #25572] Thu, 01 May 2003 12:59 Go to previous message
Dear Simon et. al,
I submitted the bug. It is bug number 37139
Sinleeh
sinleeh wrote:
> Dear Simon,
> Many thanks,
> sinleeh. ;)
> > Simon :-)
> > > Dear Simon,
a
edition
> > > problem report?
> > > Best regards,
> > > Sinleeh
> > > > Simon :-)
> > > > > Dear Simon et.al.,
> > version
> > connect
> > > > > my editor to.
plugin.xml
> > any
> > > > > extension points.
> > section
lot
> > of
> > > > > Best regards,
> > > > > sinleeh
in
> > the
> > > > > > Simon :-)
> > > > > > > Dear all,
> > > > define a
> > that
the
> > > > case.
> > > > > > > Sinleeh
Previous Topic:Why does eclipse have linux motif and gtk2 build separately?
Next Topic:Slush Bucket (PickList)
Current Time: Sat Nov 08 04:02:01 EST 2025
Powered by FUDForum. Page generated in 0.03567 seconds
