Home » Language IDEs » C / C++ IDE (CDT) » Re: `/etc/startup.mk' not found
Re: `/etc/startup.mk' not found [message #234267] Tue, 26 May 2009 12:41 Go to next message
Richard wrote:
> I am trying to run ganymede on a Windows XP pro based pc for the first
> time. I am trying to build the Hello World example. When I select Clean
> and then it attempts to rebuild, I get this error. I have searched the
> web pretty thoroughly, but can not find out what I am doing wrong.
> **** Build of configuration Default for project HelloWorldRAP ****
> make all make: Error -- Configuration file `/etc/startup.mk' not found
> I even tried some stuff from a command prompt window:
> Microsoft Windows XP [Version 5.1.2600]
> (C) Copyright 1985-2001 Microsoft Corp.
> p:\>make --version
> Defined macro MAKECMD=make
> make: Unknown option --
> Usage: make [-eEiMnpqrstuvVx] [-k|-S] [-c dir] [-D macro=value] [-f
> file] [macro
> =value ...] [target ...]
> Note: I do also have MKS integrity installed for another project. But,
> I also have another co-worker that does not and they are having this
> same problem.
Re-routed to CDT
Paul Webster
Re: `/etc/startup.mk' not found [message #234276 is a reply to message #234267] Tue, 26 May 2009 16:28 Go to previous messageGo to next message
Paul Webster wrote:
> Re-routed to CDT
Paul, I am new here, so I apologize. I see this got re-routed to CDT
section. And that is fine. I am not sure if the rest of the links in
your post were some kind of an answer. I could not make sense of them I
am afraid. Can you possibly point me in the proper direction for my 2
problems?
Thanks, Rick
Re: `/etc/startup.mk' not found [message #234325 is a reply to message #234267] Wed, 27 May 2009 22:20 Go to previous message
>> Clean and then it attempts to rebuild, I get this error. I have
>> searched the web pretty thoroughly, but can not find out what I am
>> doing wrong.
>> p:\>make --version
>> file] [macro
>> But, I also have another co-worker that does not and they are having
>> this same problem.
> Re-routed to CDT
The message appears to be coming from make. Eclipse uses the make
utility installed on your system. Have you looked at the documentation
for your make program to see if that gives any clues?
Previous Topic:Re: `/etc/startup.mk' not found
Next Topic:How to set a build configuration for a Project Template?
Current Time: Thu Oct 30 15:42:38 EDT 2025
Powered by FUDForum. Page generated in 0.05866 seconds
