Home » Modeling » Epsilon » how to give an Ecore DataType to an attribute
how to give an Ecore DataType to an attribute [message #22911] Tue, 14 July 2009 12:12 Go to next message
Hi;
I want to transform a model to an ecore metamodel(EM), but I am having a
problem in giving Ecore EString type to an EAttribute.
Here is my simple rule:
rule testRule
transform sf : FM!FeatureModel
to tf : EM!EPackage {
tf.name := sf.name;
for(f in FM.allInstances)
var ec : new EM!EClass;
ec.name:=f.name;
tf.eClassifiers.add(ec);
if(f.isTypeOf(Feature) or f.isTypeOf(Group))
var card : new EM!EAttribute;
card.name := 'Cardinality';
--var eType : new EM!ETypeParameter;
--eType.name := 'EString';
--card.eType := eType;
card.eType := EString; -- this gives the error, even EM.EString doesnt
work
--card.eAttributeType := eType;
card.lowerBound := f.Min;
card.upperBound := f.Max;
ec.eAttributes.add(card);
I dont want to do it through the variable eType as I want to use Ecore's
built-in data type. I've just started using EMF/ETL and hence this basic
question:)
Any help would be great.
cheers
--Ali
Re: how to give an Ecore DataType to an attribute [message #22956 is a reply to message #22911] Tue, 14 July 2009 12:28 Go to previous messageGo to next message
Hi Ali,
In this case you need to add Ecore as a third model to your
transformation in the launch configuration (Models->Add->Registered EMF
Package and select http://www.eclipse.org/emf/2002/Ecore as the
metamodel URI and set the name to Ecore)
Then you can get EString like this:
card.eType := Ecore!EDataType.all.selectOne(dt|dt.name = 'EString');
Dimitris
Ali Gondal wrote:
> Hi;
> rule testRule transform sf : FM!FeatureModel
> tf.name := sf.name;
> for(f in FM.allInstances) {
> ec.name:=f.name;
> tf.eClassifiers.add(ec); if(f.isTypeOf(Feature)
> EM.EString doesnt work
> ec.eAttributes.add(card); }
> question:)
> cheers
> --Ali
Re: how to give an Ecore DataType to an attribute [message #23041 is a reply to message #22956] Tue, 14 July 2009 12:36 Go to previous message
Many thanks for your help and quick response.
--Ali
Re: how to give an Ecore DataType to an attribute [message #570894 is a reply to message #22911] Tue, 14 July 2009 12:28 Go to previous message
Hi Ali,
Dimitris
Ali Gondal wrote:
> Hi;
> tf.name := sf.name;
> ec.name:=f.name;
> question:)
> cheers
> --Ali
Re: how to give an Ecore DataType to an attribute [message #570944 is a reply to message #22956] Tue, 14 July 2009 12:36 Go to previous message
--Ali
Previous Topic:how to give an Ecore DataType to an attribute
Next Topic:EuGENia link attributes
Current Time: Sat Nov 08 06:21:04 EST 2025
Powered by FUDForum. Page generated in 0.04185 seconds
