Home » Modeling » M2T (model-to-text transformation) » Content assist/Locating error in JETEditor
Content assist/Locating error in JETEditor [message #22885] Wed, 20 June 2007 05:56 Go to next message
Originally posted by: psentosa.yahoo.com
Hi all,
hope this is the right for asking question on JETEditor.
Right now I use EMFT-JET (0.8.0.v20070517) and EMFT-JET editor
(0.8.0.v200703030036).
In the documentation, it is stated that within a scriplet, the code assist /
locating error - features are possible.
But until now, I still can't use / see both of them (no content assist with
Ctrl+Space, no info on errors within scriplet).
Can anyone please explain how to get both of them? Is there any
pre-requirement?
It is really a tedious work using JET without having them.
Thanks in advance!
Re: Content assist/Locating error in JETEditor [message #23716 is a reply to message #22885] Sun, 24 June 2007 06:00 Go to previous messageGo to next message
Hi again,
has anyone ever got the same problem?
Or do these features always work in your case?
ps
"Paul Sentosa" <psentosa@yahoo.com> schrieb im Newsbeitrag
news:f5atk2$3er$1@build.eclipse.org...
> Hi all,
with
> pre-requirement?
> Thanks in advance!
> Regards
Re: Content assist/Locating error in JETEditor [message #24678 is a reply to message #23716] Sat, 30 June 2007 03:52 Go to previous messageGo to next message
Originally posted by: jcheuoua.ilog.com
Hello Paul,
EMFT-JET editor doesn't work with EMFT-JET (I know this is far from being
intuitive ;)). It's working for EMF-GenModel JET.
You should use the M2T plug-ins that packages compatible JET and JET editor
components.
http://www.eclipse.org/modeling/m2t/downloads/
I hope this helps.
Joel.
"Paul Sentosa" <psentosa@yahoo.com> wrote in message
news:f5lfbq$4h4$1@build.eclipse.org...
> Hi again,
> Thanks
> ps
>> Hi all,
>> assist
> with
>> pre-requirement?
>> Thanks in advance!
>> Regards
Re: Content assist/Locating error in JETEditor [message #24793 is a reply to message #24678] Tue, 03 July 2007 05:40 Go to previous messageGo to next message
Hi Joel...
thanks for your answer. But sorry, I'm still not very clear here.
Are you saying that JET editor only works for certain JET files
(EMF-GenModel JET) and not for my self-created /arbitrary JET files?
I'm already using the plug-ins you mention:
JET: m2t-jet-SDK-0.8.0M7.zip
JET Editor: emft-jeteditor-SDK-I200703030036.zip
but still it doesn't work.
Thanks again for any explanation
Paul
"Joel Cheuoua" <jcheuoua@ilog.com> schrieb im Newsbeitrag
news:f6524e$nno$1@build.eclipse.org...
> Hello Paul,
editor
> components.
> I hope this helps.
> Joel.
> > Hi again,
> > Thanks
> > ps
> >> Hi all,
> >> assist
> > with
> >> pre-requirement?
> >> Thanks in advance!
> >> Regards
Re: Content assist/Locating error in JETEditor [message #25207 is a reply to message #24793] Fri, 06 July 2007 07:19 Go to previous message
Hello Paul,
news:f6d5hm$joe$1@build.eclipse.org...
> Hi Joel...
More accurately, the "EMFT-JET Editor" is working for any JET files
compliant to the former EMF-CodeGen JET technology (aka JET1).
JET has evolved since then into a better technology as part of the efforts
of the "EMFT-JET" (aka JET2) component.
Unfortunately, and we know this is confusing, the "EMFT-JET Editor" was not
targeting the JET2 technology.
But we fixed that within the M2T project, where the new JET core and the JET
editor components are working for every JET files, whatever the JET
technology version is.
You'll find this very same answer by browsing the m2t newsgroup. To make it
short :
EMF-CodeGen = JET1
EMFT = JET2 + JET1 Editor
M2T = JET2/JET1 + JET2/JET1 Editor
You should use m2t-jet-editor-0.8.0.zip from the M2T download page.
Joel.
> Regards
> Paul
>> Hello Paul,
> editor
>> components.
>> I hope this helps.
>> Joel.
>> > Hi again,
>> > Thanks
>> > ps
>> >> Hi all,
>> >> assist
>> > with
>> >> pre-requirement?
>> >> Thanks in advance!
>> >> Regards
Previous Topic:User of infant JET
Next Topic:running jet application
Current Time: Fri Nov 21 03:16:39 EST 2025
Powered by FUDForum. Page generated in 0.20314 seconds
