Home » Eclipse Projects » Equinox » Questions about OSGi
Questions about OSGi [message #22862] |
Mon, 14 April 2003 10:14  |
I spent some time over the week end reading the OSGi specs and I have some
questions:
- When the framework is shutdown, bundle states are saved. Is there any
other information saved (the instances, the internal state of each bundle)?
Does a bundle as a chance to do something on saving?
- How is the platform state restored? For example when the platform has
been shatdown the bundle A was ACTIVE. Is the bundle A defacto ACTIVE when
the platform restart, or does it go through the regular lifecycle stage of
INSTALLED, RESOLVED, ACTIVE sent? Will the start() method on the
bundleActivator of A be called?
- Can a bundle contain jars whose code will be used?
- Can a bundle contain bundles?
- Why is there no RESOLVED event?
- Is it really possible to access resources from an INSTALLED bundle?
Thank you in advance,
PaScaL
Re: Questions about OSGi [message #22907 is a reply to message #22862] |
Tue, 15 April 2003 03:10   |
Each bundle has its own private data area, it can save whatever it wants
in there.
The stop() method is called on the BundleActivator, the bundle can do
whatever it likes in there.
It will go through the normal life cycle methods. I.e. there is no magic
data stored, only fact that a bundle should be started when the
framework is started. The bundle will come alive in the INSTALLED state,
and then has to move to RESOLVED before it is started and becomes ACTIVE.
Yes, this is supported with the Bundle-Classpath manifest header that
contains a list of JAR files in the Bundle's JAR file. This is a very
useful feature that I wish was supported by normal Java.
Yes. Installing a bundle is from a URL or InputStream, so installing a
bundle in a bundle is like context.installBundle(
getClass().getResource("bundle.jar").toString() ); This is used
extensively in the OSGi test suites.
The need never arose. Do you have a use case for it?
Yes, through the Bundle.getResource method.
Hope this helps, kind regards,
Peter Kriens
Re: Questions about OSGi [message #22951 is a reply to message #22862] |
in there.
Peter Kriens
Re: Questions about OSGi [message #23081 is a reply to message #22907] |
Tue, 15 April 2003 10:10  |
That's great,
PaScaL
"pkriens" <Peter.Kriens@aQute.se> wrote in message
news:3E9BB061.3050803@aQute.se...
any
bundle)?
> in there.
has
when
of
bundle?
> Peter Kriens
Current Time: Sun Oct 19 21:27:32 EDT 2025
Powered by FUDForum. Page generated in 0.05285 seconds
