Home » Eclipse Projects » Remote Application Platform (RAP) » Table Refresh Error
Table Refresh Error [message #22828] Mon, 07 May 2007 18:09 Go to next message
I have a view part which shows a search result in a TableViewer.
The search string is provided via a Text criteria and a modify
listener is bound to it. The modify Listener updates the table with
viewer.refresh();
That works fine when the number of search results are growing. When
a search result get less results then the one before I get the following
Error:
org.eclipse.jface.util.Assert$AssertionFailedException: null argument;
at org.eclipse.jface.util.Assert.isNotNull(Assert.java:146)
at org.eclipse.jface.util.Assert.isNotNull(Assert.java:122)
org.eclipse.jface.viewers.StructuredViewer.disassociate(Stru cturedViewer.java:563)
org.eclipse.jface.viewers.TableViewer.internalRefreshAll(Tab leViewer.java:884)
org.eclipse.jface.viewers.TableViewer.internalRefresh(TableV iewer.java:799)
org.eclipse.jface.viewers.TableViewer.internalRefresh(TableV iewer.java:783)
org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredV iewer.java:1328)
org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1268)
org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:1325)
org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:1287)
de.todo.bpm.client.view.SearchViewBase$1.modifyText(SearchVi ewBase.java:84)
this does not happen when I dispose the table in the viewer and recreate
it.
Any ideas ?
Thomas
Re: Table Refresh Error [message #22872 is a reply to message #22828] Mon, 07 May 2007 19:44 Go to previous messageGo to next message
i solved the problem myself :-)
just added
viewer.getTable().removeAll();
befored refresh.
Thanks for attention,
thomas
"Thomas K
Re: Table Refresh Error [message #25695 is a reply to message #22872] Fri, 18 May 2007 02:17 Go to previous message
Hi Thomas,
removeAll() is a workaround, however, refresh() should work, in my opinion.
I created a bugreport https://bugs.eclipse.org/bugs/show_bug.cgi?id=187272
Greetings,
Stefan.
"Thomas K
Previous Topic:File Uploader Widget
Next Topic:Unsupported event handler
Current Time: Thu Nov 06 03:40:42 EST 2025
Powered by FUDForum. Page generated in 0.25436 seconds
