| Undefined reference to inherited interface [message #233353] |
Tue, 28 April 2009 07:09 |
Hi to all,
I experience the following problem with Eclipse CDT 3.3.2 and C/C++ plugin
4.0.3
I have to do the porting of a project (developped under windows with
VisualC++) to eclipse cdt under linux (suse 10)
After lots and lots of attempts I managed to import the sources give the
right paths of source files and link the libraries.I'm using the automatic
make file of the eclipse cdt.
So building went on fine. While linking stops with a strange error to the
heritage of an interface with the following error message.
**** Build of configuration Release for project ReportToolExe ****
make all
Building target: ReportToolExe
Invoking: GCC C++ Linker
g++ -L/opt/tools/1.26.2/lib/suse9.1-gcc3_p4
-L/opt/tools/QT/xerces-c_2_8_0-x86-linux-gcc_3_4/lib
-L/opt/tools/QT/qt-x11-eval-src-4.4.3/lib -L/opt/tools/fltk-1.1.0/lib
-o"ReportToolExe" ./ReportingMessages/ReportingMessages.o
/ReportingGUI/BufferTriggerEditor.o ./ReportingGUI/ClientItem.o
/ReportingGUI/ClientList.o ./ReportingGUI/ClientPropertiesEditor.o
/ReportingGUI/ClientPropertyFilters.o ./ReportingGUI/ClientsTab.o
/ReportingGUI/ConfigChooser.o ./ReportingGUI/ConfigDisplay.o
/ReportingGUI/ConfigTab.o ./ReportingGUI/FiltersTab.o
/ReportingGUI/GeneralPropertiesEditor.o
/ReportingGUI/GlobalOutputDestinationEditor.o ./ReportingGUI/GroupItem.o
/ReportingGUI/GroupList.o ./ReportingGUI/GroupPropertiesEditor.o
/ReportingGUI/HelpViewer.o ./ReportingGUI/ListManager.o
/ReportingGUI/ReportingGUI.o ./ReportingGUI/Resources.o
/ReportingGUI/ResultDisplay.o ./ReportingGUI/TristateCheckBox.o
/ReportingGUI/UpdateThread.o ./ReportingGUI/main.o
/ReportingGUI/generatedfiles/release/moc_BufferTriggerEditor .o
/ReportingGUI/generatedfiles/release/moc_ClientList.o
/ReportingGUI/generatedfiles/release/moc_ClientPropertiesEdi tor.o
/ReportingGUI/generatedfiles/release/moc_ConfigChooser.o
/ReportingGUI/generatedfiles/release/moc_GeneralPropertiesEd itor.o
/ReportingGUI/generatedfiles/release/moc_GlobalOutputDestina tionEditor.o
/ReportingGUI/generatedfiles/release/moc_GroupList.o
/ReportingGUI/generatedfiles/release/moc_GroupPropertiesEdit or.o
/ReportingGUI/generatedfiles/release/moc_ReportingGUI.o
/ReportingGUI/generatedfiles/release/moc_ResultDisplay.o
/ReportingGUI/generatedfiles/release/moc_TristateCheckBox.o
/Reporting/Test/ReportingTestLibrary.o
/Reporting/Test/ReportingTestThread.o ./Reporting/Protocol/RecvThread.o
/Reporting/Protocol/ReportingByteReader.o
/Reporting/Protocol/ReportingByteWriter.o
/Reporting/Protocol/SendThread.o ./Reporting/OutputDevice/Clipboard.o
/Reporting/OutputDevice/ConsoleOutputDevice.o
/Reporting/OutputDevice/CyclicBuffer.o
/Reporting/OutputDevice/FileOutputDevice.o
/Reporting/OutputDevice/OutputDeviceException.o
/Reporting/OutputDevice/OutputThread.o
/Reporting/OutputDevice/OutputThreadException.o
/Reporting/OutputDevice/WindowControl.o
/Reporting/OutputDevice/WindowOutputDevice.o
/Reporting/Master/CheckActiveThread.o ./Reporting/Master/CommThread.o
/Reporting/Master/Config.o ./Reporting/Master/Messages.o
/Reporting/Master/ReportingServerDefinitions.o
/Reporting/Implementation/CLErrorHandler.o
/Reporting/Implementation/Error.o ./Reporting/Implementation/Reporting.o
/Reporting/Implementation/ReportingC.o
/Reporting/Implementation/ReportingDummyImpl.o
/Reporting/Implementation/ReportingImpl.o
/Reporting/Implementation/ReportingProxyImpl.o
/Definitions/ReportingDefs.o ./Configuration/FileSystem.o
/Configuration/ReportingCfg.o ./Configuration/XMLConfigurationFile.o
/CommonFile/ClientHandler.o ./CommonFile/ClientsFile.o
/CommonFile/CommonFileFacade.o ./CommonFile/ControlFile.o
/CommonFile/ControlHandler.o ./CommonFile/DefaultProperties.o
/CommonFile/UpdatingData.o ./CommonFile/XMLPersistence.o
/CommonDataInterface/CommonDataException.o
/CommonDataInterface/CommonDataTypes.o -lcommon -lxerces-c
-lxerces-depdom -lQtGui -lQtCore -lfltk -lfltk_forms -lfltk_gl
-lfltk_images
/Reporting/Implementation/ReportingImpl.o: In function
`Reporting::deleteInstance()':
ReportingImpl.cpp:(.text+0x160): multiple definition of
/Reporting/Implementation/ReportingDummyImpl.o:ReportingDumm yImpl.cpp:(.text+0xb0):
first defined here
/usr/lib/gcc/i586-suse-linux/4.1.2/../../../../i586-suse-lin ux/bin/ld:
Warning: size of symbol `Reporting::deleteInstance()' changed from 104 in
/Reporting/Implementation/ReportingDummyImpl.o to 105 in
`Reporting::instance()':
ReportingImpl.cpp:(.text+0x96a0): multiple definition of
/Reporting/Implementation/ReportingDummyImpl.o:ReportingDumm yImpl.cpp:(.text+0x900):
first defined here
Warning: size of symbol `Reporting::instance()' changed from 146 in
/Reporting/Implementation/ReportingDummyImpl.o to 147 in
/Reporting/Implementation/ReportingProxyImpl.o: In function
ReportingProxyImpl.cpp:(.text+0x440): multiple definition of
first defined here
ReportingProxyImpl.cpp:(.text+0xdc0): multiple definition of
first defined here
Warning: size of symbol `Reporting::instance()' changed from 147 in
/Reporting/Implementation/ReportingDummyImpl.o to 153 in
/Reporting/OutputDevice/WindowControl.o: In function
`WindowControl::waitUntilReceived(CL::Message*)':
WindowControl.cpp:(.text+0x36): undefined reference to `Fl::awake(void*)'
WindowControl.cpp:(.text+0x56): undefined reference to `Fl::awake(void*)'
`WindowControl::threadCode()':
WindowControl.cpp:(.text+0x1d0): undefined reference to `Fl::lock()'
WindowControl.cpp:(.text+0x24c): undefined reference to `Fl::unlock()'
`WindowControl::destroyWindow(WindowOutputDevice&)':
WindowControl.cpp:(.text+0x6ce): undefined reference to `Fl::awake(void*)'
WindowControl.cpp:(.text+0x6f4): undefined reference to `Fl::awake(void*)'
`WindowControl::createWindow(WindowOutputDevice&)':
WindowControl.cpp:(.text+0x78e): undefined reference to `Fl::awake(void*)'
WindowControl.cpp:(.text+0x7b4): undefined reference to `Fl::awake(void*)'
`WindowControl::~WindowControl()':
WindowControl.cpp:(.text+0x9cd): undefined reference to `Fl::awake(void*)'
/Reporting/OutputDevice/WindowControl.o:WindowControl.cpp:(. text+0x9e7):
more undefined references to `Fl::awake(void*)' follow
/Reporting/OutputDevice/WindowOutputDevice.o: In function
`WindowOutputDevice::write(char*, unsigned int, bool)':
WindowOutputDevice.cpp:(.text+0x1ca1): undefined reference to `Fl::lock()'
WindowOutputDevice.cpp:(.text+0x1d56): undefined reference to
`Fl::unlock()'
WindowOutputDevice.cpp:(.text+0x1d62): undefined reference to
`Fl::awake(void*)'
collect2: ld returned 1 exit status
make: *** [ReportToolExe] Error 1
Does anyone have any hint.
I'm stack and cannot go on.
Any help soul be apreciated
Thanks in Advance
Mandy
FUDForum. Page generated in 0.03795 seconds
