Home » Eclipse Projects » JFace » JFace_Data_Binding/DOM Example
JFace_Data_Binding/DOM Example [message #22812] Wed, 22 July 2009 12:51 Go to next message
I am trying to run the examples from JFace Data Binding/DOM
http://wiki.eclipse.org/JFace_Data_Binding/DOM
I've downloaded both components and imported the examples project. I then
added the plug-in to the build path libraries. Also, added
org.eclipse.core.databind.property plug-in. Everything compiles fine but
when I run I get this error.
org.eclipse.core.databinding.BindingException: converter does not convert
to type class org.apache.xerces.dom.DeferredDocumentImpl Expected:
interface org.w3c.dom.Document, actual: class
org.eclipse.core.databinding.UpdateStrategy.checkAssignable( UpdateStrategy.java:97)
and other stuff
Did I set the project up wrong or am I missing something? Any help is
appreciated . Thanks.
Stephen
Re: JFace_Data_Binding/DOM Example [message #23153 is a reply to message #22812] Wed, 22 July 2009 17:18 Go to previous messageGo to next message
Stephen,
I suspect you are binding to the wrong object, but we need to see your
binding code to be sure. A standalone snippet would be ideal.
Note that the DOM observables are not an Eclipse project (yet!) so you
may have better luck contacting the TK-UI project maintainers on
Sourceforge.
Matthew
> then added the plug-in to the build path libraries. Also, added
> convert to type class org.apache.xerces.dom.DeferredDocumentImpl
> Expected: interface org.w3c.dom.Document, actual: class
> at
> and other stuff
> Stephen
Re: JFace_Data_Binding/DOM Example [message #23620 is a reply to message #23153] Thu, 23 July 2009 09:31 Go to previous message
All I am trying to do is run the examples so I haven't changed anything. I
will contact the maintainers and see what they have to say. Thanks for
your advice. I'm still new at this but I'm glad so many people are willing
to help.
Stephen
Previous Topic:Changing foreground/background color of selected table row
Next Topic:MultiValidator disposal
Current Time: Sat Nov 15 19:43:22 EST 2025
Powered by FUDForum. Page generated in 0.04374 seconds
