Home » Eclipse Projects » DSDP - Target Management » ftp connection hangs after a long inactive time.
ftp connection hangs after a long inactive time. [message #22778] Thu, 15 May 2008 07:52 Go to next message
I am connected to a remote site which uses some
routers/switches/firewalls that drop a session after some idle time (I
read somewhere that cheap Cisco firewalls have that problem).
So every time I take a coffee break ssh and ftp sessions with or without
Eclipse hang.
Can dsdp target management be configured to restart a session whenever
that happens?
David Harel
Amuka
Israel
Re: ftp connection hangs after a long inactive time. [message #22954 is a reply to message #22778] Thu, 15 May 2008 18:53 Go to previous messageGo to next message
For ssh / sftp, what version of RSE are you using?
We added a keepalive feature in RSE 2.0.3 / RSE 3.0M6, which
should avoid that kind of issues.
For FTP, I was under the impression that it does reconnect
automatically, in fact doesn't even notice the dropped
connection, or am I mistaken?
If I am mistaken, would you please file a bug (enhancement
request) for this?
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
David Harel wrote:
> Eclipse hang.
> that happens?
> Thanks
> David Harel
> Amuka
> Israel
Re: ftp connection hangs after a long inactive time. [message #23040 is a reply to message #22954] Fri, 16 May 2008 12:11 Go to previous messageGo to next message
I use RSE 2.0.3.v20080225
I couldn't find where this setting is. Please guide me.
I had the same impression but I don't know how to verify that and
therefore I would avoid submitting a bug report until I know what I see.
Anyway, I changed to fssh which seems to get disconnected after every
file transfer and therefore avoids the problem all together.
Thanks for your help.
> request) for this?
> David Harel wrote:
>> without Eclipse hang.
>> that happens?
>> Thanks
>> David Harel
>> Amuka
>> Israel
Thanks.
David Harel,
Home office +972 77 7657645
Fax: +972 77 7657645
Cellular: +972 54 4534502
Snail Mail: Amuka
D.N Merom Hagalil
13802
Israel
Re: ftp connection hangs after a long inactive time. [message #23087 is a reply to message #22954] Fri, 16 May 2008 12:23 Go to previous messageGo to next message
> request) for this?
> David Harel wrote:
>> that happens?
>> Thanks
>> David Harel
>> Amuka
>> Israel
Thanks.
David Harel,
Snail Mail: Amuka
D.N Merom Hagalil
13802
Israel
Re: ftp connection hangs after a long inactive time. [message #23128 is a reply to message #23087] Sun, 18 May 2008 10:03 Go to previous messageGo to next message
In the New Connection Wizard, below "SSH Connector Service" there
is an "SSH Settings" node. Select it and you can enter the
keepalive (default is 300 seconds, so RSE would send a keepalive
packet every 5 minutes).
If your connection already exists, select the host, right-click
> properties, select the "Connector Servcies" / "SSH Settings"
node, and voila you see the keepalive time (300 by default).
Window > Show View > Other... > General > Console
Click on "Computer" icon to switch to the FTP Log Console
You'll see the log of FTP commands so you'll see if and where
the connection is (re-)established.
In general, don't be afraid of entering a bug. In the worst
case, a committer will come and set it to "WORKSFORME" or
ask you to provide more information. Please, don't be shy.
Just see bugzilla as a communication platform, where the
comments (just as I'm typing right now) are stored in a
much more accessible, ordered and searchable database than
here on the newsgroup.
Martin
Re: ftp connection hangs after a long inactive time. [message #23233 is a reply to message #23128] Tue, 20 May 2008 04:04 Go to previous messageGo to next message
Thank you for your help.
I filed a bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=232915
I didn't find the "SSH settings" node. Is it a version issue?
> Cheers,
> Martin
Thanks.
David Harel,
Snail Mail: Amuka
D.N Merom Hagalil
13802
Israel
Re: ftp connection hangs after a long inactive time. [message #23323 is a reply to message #23233] Tue, 20 May 2008 12:47 Go to previous message
Probably yes.
Discussion continued on https://bugs.eclipse.org/bugs/show_bug.cgi?id=232915
Martin
Re: ftp connection hangs after a long inactive time. [message #574666 is a reply to message #22778] Thu, 15 May 2008 18:53 Go to previous message
request) for this?
David Harel wrote:
> Eclipse hang.
> that happens?
> Thanks
> David Harel
> Amuka
> Israel
Re: ftp connection hangs after a long inactive time. [message #574720 is a reply to message #22954] Fri, 16 May 2008 12:11 Go to previous message
> request) for this?
> David Harel wrote:
>> that happens?
>> Thanks
>> David Harel
>> Amuka
>> Israel
Thanks.
David Harel,
Snail Mail: Amuka
D.N Merom Hagalil
13802
Israel
Re: ftp connection hangs after a long inactive time. [message #574727 is a reply to message #22954] Fri, 16 May 2008 12:23 Go to previous message
> request) for this?
> David Harel wrote:
>> that happens?
>> Thanks
>> David Harel
>> Amuka
>> Israel
Thanks.
David Harel,
Snail Mail: Amuka
D.N Merom Hagalil
13802
Israel
Re: ftp connection hangs after a long inactive time. [message #574754 is a reply to message #23087] Sun, 18 May 2008 10:03 Go to previous message
Martin
Re: ftp connection hangs after a long inactive time. [message #574836 is a reply to message #23128] Tue, 20 May 2008 04:04 Go to previous message
> Cheers,
> Martin
Thanks.
David Harel,
Snail Mail: Amuka
D.N Merom Hagalil
13802
Israel
Re: ftp connection hangs after a long inactive time. [message #574850 is a reply to message #23233] Tue, 20 May 2008 12:47 Go to previous message
Probably yes.
Martin
Previous Topic:Trying to do remote debuging on a AIX host from a Windows client
Next Topic:VxWorks TCF Agent
Current Time: Thu Jul 10 02:21:23 EDT 2025
Powered by FUDForum. Page generated in 0.04614 seconds
