Home » Newcomers » Newcomers » opengl / glut in eclipse
opengl / glut in eclipse [message #232575] Fri, 14 September 2007 05:52 Go to next message
Originally posted by: athalemica.yahoo.com.au
I've been trying to figure out how to get glut and openGl working in
eclipse to no success. I'm using eclipse 3.3 and this is the code i'm using
/* Demo.cpp
* A simple OpenGL program using GLUT. It creates a blank black
* window which can be used as a starting point for OpenGL programming.
* Link in opengl32, glu32, and glut32 libraries and make sure to include
* windows.h if you are compiling with Eclipse in Windows.
* Author: Paul Solt 3-4-07
* Based on examples from the Red book OpenGL Programming Guide
#include <windows.h>
#include <GL/glut.h>
const int WIDTH = 600;
const int HEIGHT = 480;
/* Prototypes */
void init();
void display();
/* Definitions */
/* Initializes the OpenGL state */
void init() {
glClearColor( 0.0, 0.0, 0.0, 1.0 ); /* Set the clear color */
/* Displays a black clear screen */
void display() {
glClear( GL_COLOR_BUFFER_BIT ); /* Clear the screen with the clear color
glutSwapBuffers(); /* Double buffering */
/* The main function */
int main( int argc, char *argv[] ) {
/* Glut setup function calls */
glutInit( &argc, argv );
glutInitDisplayMode( GLUT_DOUBLE | GLUT_RGB ); /* Use double buffering
and RGB colors */
glutInitWindowPosition( 100, 100 );
glutInitWindowSize( WIDTH, HEIGHT );
glutCreateWindow( argv[0] );
init();
glutDisplayFunc( display ); /* Call back display function */
glutMainLoop(); /* Continue drawing the scene */
return 0;
I am using MinGW for the compiling,
and these are my errors...
Severity and Description Path Resource Location Creation Time Id
src\glutDemo.o: In function `glutCreateMenu_ATEXIT_HACK':C:/Program
Files/MinGW/bin/../lib/gcc/mingw32/3.4.2/../../../../include /GL/glut.h
undefined reference to `__glutCreateMenuWithExit@8' glutDemo line
546 1189763239410 72
src\glutDemo.o: In function `glutCreateWindow_ATEXIT_HACK':C:/Program
undefined reference to `__glutCreateWindowWithExit@8' glutDemo line
500 1189763239410 71
src\glutDemo.o: In function `glutInit_ATEXIT_HACK':C:/Program
undefined reference to `__glutInitWithExit@12' glutDemo line
483 1189763239410 70
undefined reference to `glClear@4' glutDemo/src glutDemo.cpp line
30 1189763239410 74
undefined reference to `glClearColor@16' glutDemo/src glutDemo.cpp line
25 1189763239410 73
undefined reference to `glutDisplayFunc@4' glutDemo/src glutDemo.cpp line
43 1189763239410 79
`glutInitDisplayMode@4' glutDemo/src glutDemo.cpp line 38 1189763239410 76
`glutInitWindowPosition@8' glutDemo/src glutDemo.cpp line
39 1189763239410 77
`glutInitWindowSize@8' glutDemo/src glutDemo.cpp line 40 1189763239410 78
undefined reference to `glutMainLoop@0' glutDemo/src glutDemo.cpp line
44 1189763239410 80
undefined reference to `glutSwapBuffers@0' glutDemo/src glutDemo.cpp line
31 1189763239410 75
does anyone know how to fix this up?
Re: opengl / glut in eclipse [message #232605 is a reply to message #232575] Fri, 14 September 2007 06:55 Go to previous message
Ryan,
This sounds like a question that might get better attention on the CDT
newsgroup: news://news.eclipse.org/eclipse.tools.cdt
> using
> /* Demo.cpp
> * * Link in opengl32, glu32, and glut32 libraries and make sure to
> include
> * * Author: Paul Solt 3-4-07
> /* Prototypes */
> void init();
> void display();
> /* Definitions */
> void init() {
> void display() {
> color */
> buffering and RGB colors */
> init();
> return 0;
> Time Id
> line 546 1189763239410 72
> glutDemo line 500 1189763239410 71
> line 30 1189763239410 74
> glutDemo.cpp line 25 1189763239410 73
> glutDemo.cpp line 43 1189763239410 79
> undefined reference to `glutInitDisplayMode@4' glutDemo/src
> undefined reference to `glutInitWindowPosition@8' glutDemo/src
> glutDemo.cpp line 39 1189763239410 77
> undefined reference to `glutInitWindowSize@8' glutDemo/src
> glutDemo.cpp line 44 1189763239410 80
> glutDemo.cpp line 31 1189763239410 75
Previous Topic:Can I use my own debuggger (DDD)?
Next Topic:p
Current Time: Tue Nov 11 17:35:27 EST 2025
Powered by FUDForum. Page generated in 0.08334 seconds
