Home » Archived » Riena » Server Side Preferences
Server Side Preferences [message #22683] Tue, 10 March 2009 04:39 Go to next message
Hello
For my Server/Client application I need to handle the preferences on the
server.
Does Riena provide (or will in the future) a server side preference store?
I tried to publish and access the
org.osgi.service.prefs.PreferencesService without success.
Thanks for any information.
Flavio
Re: Server Side Preferences [message #22728 is a reply to message #22683] Tue, 10 March 2009 10:41 Go to previous messageGo to next message
We are (like any on else) driven by what we see in bugzilla and first of all by what our customers want. Although I have
heard of requirement for user preferences stored on the server we havnt planned to implement that yet.
I am not sure if IPreferencesServices is a good interface for remote services but you should be able to do it anyway.
The only problem is really that you always have an IPreferencesServices OSGi service (also on the client) and when
injecting you need to local preference store apart from the remote proxy of the preference store. But that sounds doable.
What were your problems when doing that yourself ?
christian
Flavio Donzé schrieb:
> Hello
> server.
> Flavio
Re: Server Side Preferences [message #22904 is a reply to message #22728] Thu, 12 March 2009 18:06 Go to previous messageGo to next message
.... I think that treat the preferences in hand server through API would
be great.
> christian
>> Hello
>> server.
>> Flavio
Re: Server Side Preferences [message #22947 is a reply to message #22728] Fri, 13 March 2009 13:13 Go to previous message
Hi Christian
On the client I get the following exception when I call
service.getSystemPreferences();
osgi> 13.03.2009 18:01:46 com.caucho.hessian.io.SerializerFactory
getDeserializer
WARNUNG: Hessian/Burlap:
'org.eclipse.core.internal.resources.ProjectPreferences' is an unknown
class in org.eclipse.core.runtime.internal.adaptor.ContextFinder@a6fed5:
java.lang.ClassNotFoundException:
13.03.2009 18:01:46 com.caucho.hessian.io.SerializerFactory getDeserializer
WARNUNG: Hessian/Burlap: 'com.softmodeler.service.ServerPlugin' is an
unknown class in
java.lang.ClassNotFoundException: com.softmodeler.service.ServerPlugin
Publishing works fine and on the client I would use the "filter" parameter
to make sure I get the remote service.
By the way I'm using the org.osgi.service.prefs.PreferencesService and not
the org.eclipse.core.runtime.preferences.IPreferencesService.
The IPreferencesService doesn't even publish (not sure), because I get
HessianProxy cannot connect to
'http://localhost:8080/hessian/IPreferencesServiceWS
on the client.
Should I add a FeatureRequest for "Remote Preferences" in BugZilla?
cheers and have a nice weekend
Flavio
> christian
>> Hello
>> server.
>> Flavio
Re: Server Side Preferences [message #581172 is a reply to message #22683] Tue, 10 March 2009 10:41 Go to previous message
christian
> Hello
> server.
> Flavio
Re: Server Side Preferences [message #581237 is a reply to message #22728] Thu, 12 March 2009 18:06 Go to previous message
be great.
> christian
>> Hello
>> server.
>> Flavio
Re: Server Side Preferences [message #581254 is a reply to message #22728] Fri, 13 March 2009 13:13 Go to previous message
Hi Christian
getDeserializer
unknown class in
on the client.
Flavio
> christian
>> Hello
>> server.
>> Flavio
Previous Topic:Additional Views in Riena
Next Topic:SwtApplication vs AbstractApplication
Current Time: Sat Aug 30 22:19:32 EDT 2025
Powered by FUDForum. Page generated in 0.05090 seconds
