How to fix problem with draging edit parts [message #231898] |
Tue, 20 March 2007 06:15  |
I have a table (Container edit part) containing cells (Also container
edit parts), each cell may contain any other objects. User can drag
objects inside cell and drag table in graphical viewer.
I found the following problem. When I select Table, Cell and any edit
part inside cell and try to drag them by mouse (mouse location at the
beginning is over edit part inside cell edit part), I have got
NullPointerException (NPE).
End of my stack:
org.eclipse.gef.tools.DragEditPartsTracker.updateTargetReque st(DragEditPartsTracker.java:603)
org.eclipse.gef.tools.DragEditPartsTracker.handleDragInProgr ess(DragEditPartsTracker.java:339)
at org.eclipse.gef.tools.AbstractTool.mouseDrag(AbstractTool.ja va:983)
at org.eclipse.gef.tools.SelectionTool.mouseDrag(SelectionTool. java:511)
at org.eclipse.gef.EditDomain.mouseDrag(EditDomain.java:226)
org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouse Moved(DomainEventDispatcher.java:357)
org.eclipse.draw2d.LightweightSystem$EventHandler.mouseMove( LightweightSystem.java:533)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:145)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
The problem in the following method of DragEditPartsTracker class:
private void captureSourceDimensions() {
List editparts = getOperationSet();
for (int i = 0; i < editparts.size(); i++) {
GraphicalEditPart child = (GraphicalEditPart)editparts.get(i);
IFigure figure = child.getFigure();
PrecisionRectangle bounds = null;
if (figure instanceof HandleBounds)
bounds = new
PrecisionRectangle(((HandleBounds)figure).getHandleBounds()) ;
else
bounds = new PrecisionRectangle(figure.getBounds());
figure.translateToAbsolute(bounds);
if (compoundSrcRect == null)
compoundSrcRect = new PrecisionRectangle(bounds);
else
compoundSrcRect = compoundSrcRect.union(bounds);
if (child == getSourceEditPart()) //!!!!!!!!!!!!!!!!!
sourceRectangle = bounds;
The method getOperationSet use the following method to create list at
the first time:
protected List createOperationSet() {
if (getCurrentViewer() != null) {
List list = ToolUtilities.getSelectionWithoutDependants(
getCurrentViewer());
ToolUtilities.filterEditPartsUnderstanding(list,
getTargetRequest());
return list;
return new ArrayList();
In this method ToolUtilities uses for filtering selected edit parts. For
example in my case I have the following list: TableEditPart,
CellEditPart, PrimitiveEditPart; after filtering: TableEditPart and it
is right, but getSourceEditPart() (marked string of code) method returns
PrimitiveEditPart and sourceRectangle field stays to be null and after
that uses in updateTargetRequest() method where I have got NPE. I think
that captureSourceDimensions() method should use another method instead
of getSourceEditPart() which will take into account edit parts filtering.
Is it GEF's bug? Or mine?
How can I fix this ussue?
Should I add this issue to bugzilla?
Boris Stepanov
Re: How to fix problem with draging edit parts [message #231993 is a reply to message #231898] |
Thu, 22 March 2007 01:16   |
Originally posted by: none.unknown.com
This is a GEF bug, and I've believe it's been fixed in 3.2.2
"Boris Stepanov" <freepriman@rambler.ru> wrote in message
news:etoc86$1ns$1@utils.eclipse.org...
> Hello,
> I have a table (Container edit part) containing cells (Also container edit
> parts), each cell may contain any other objects. User can drag objects
> I found the following problem. When I select Table, Cell and any edit part
> inside cell and try to drag them by mouse (mouse location at the beginning
> is over edit part inside cell edit part), I have got NullPointerException
> (NPE).
> End of my stack:
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> bounds = new PrecisionRectangle(((HandleBounds)figure).getHandleBounds()) ;
> else
> else
> The method getOperationSet use the following method to create list at the
> first time:
> return list;
> example in my case I have the following list: TableEditPart, CellEditPart,
> PrimitiveEditPart; after filtering: TableEditPart and it is right, but
> that captureSourceDimensions() method should use another method instead of
> Boris Stepanov
FUDForum. Page generated in 0.07199 seconds
