| DLTK javadoc - do it yourself [message #22662] |
Fri, 02 May 2008 16:52  |
Even though there is a plugin with all of the sources, I couldn't find
generated javadoc anywhere.
So, I took the time to build it.
If you import the plugin org.eclipse.dltk.core.source into your Eclipse
workspace,
then in that project directory, under src, you will see a subdirectory for
the sources for each DLTK plugin. In each subdirectory, there is the file
src.zip. I unpacked each of those zip files into plugin specific src
directories.
I've attached the batch file that I used to generate the javadoc,
and the output I got when I ran that batch file.
Chuck
Attachment: javdoc_bat.txt
(Size: 3.34KB, Downloaded 573 times)
Attachment: javadoc.log
(Size: 37.13KB, Downloaded 309 times)
| Re: DLTK javadoc - do it yourself [message #23011 is a reply to message #22662] |
Mon, 05 May 2008 15:17  |
This updated batch file gets all of the packages.
Chuck
"Chuck Doucette" <cdoucette@vaultus.com> wrote in message
news:fvfv18$tpc$1@build.eclipse.org...
> workspace,
> directories.
> Chuck
(Size: 3.19KB, Downloaded 535 times)
(Size: 140.99KB, Downloaded 436 times)
FUDForum. Page generated in 0.05582 seconds
