Home » Language IDEs » C / C++ IDE (CDT) » CDT - Run or debug - the selection cannot be launched
CDT - Run or debug - the selection cannot be launched [message #231228] Fri, 06 March 2009 11:01 Go to next message
Originally posted by: kgold.watson.ibm.com
Here's a FAQ with no answers on Google.
I can run or debug successfully by
Run - Open Run Dialog - Run
Run - Run History
If I try to run by
Clicking the Run icon
Ctrl-F11
I get
"The selection cannot be launched, and there are no recent launches"
Possibly related, the run history always shows the same name,
but does run whatever ran last.
Re: CDT - Run or debug - the selection cannot be launched [message #231236 is a reply to message #231228] Fri, 06 March 2009 11:17 Go to previous messageGo to next message
> Run - Run History
> If I try to run by
> Ctrl-F11
> I get
Try changing a preference:
Run/Debug
Launching
"Launch the selected resource"...
Derek
Re: CDT - Run or debug - the selection cannot be launched [message #231250 is a reply to message #231236] Fri, 06 March 2009 12:24 Go to previous messageGo to next message
>> Run - Run History
>> If I try to run by
>> Ctrl-F11
>> I get
> Run/Debug
> Launching
Thanks for responding, Could you give a bit more detail?
- I don't have a Run/Debug menu selection.
- I have Run, but there's no Launching under it
- Right clicking the project -> Properties yields a Run/Debug Settings
selection, but Launch Configurations is empty.
This is Eclipse 3.3.2 on Windows, if that matters.
Re: CDT - Run or debug - the selection cannot be launched [message #231258 is a reply to message #231250] Fri, 06 March 2009 12:43 Go to previous messageGo to next message
>>> Run - Run History
>>> If I try to run by
>>> Ctrl-F11
>>> I get
>> Run/Debug
>> Launching
I said a *preference* not a property. Windows->Prefrences
Derek
Re: CDT - Run or debug - the selection cannot be launched [message #231267 is a reply to message #231258] Fri, 06 March 2009 13:00 Go to previous messageGo to next message
>>> Run/Debug
>>> Launching
Found it.
Under Launching,
'Launch the selected resource' is selected.
'Launch the associated project' is selected.
Under Default Launchers, it's empty
Under Launch Configurations, everything is selected except
Filter checked launch configuration types.
[To the developers: I can appreciate the incredible flexibility of the
properties and preferences, but it sure would make sense to me for the
Run button to run the program by default.]
Re: CDT - Run or debug - the selection cannot be launched [message #231287 is a reply to message #231267] Sat, 07 March 2009 00:02 Go to previous messageGo to next message
Ken Goldman wrote:
>>>> Run/Debug
>>>> Launching
> Found it.
> Under Launching,
Select Always launch the previously launched application in the Launch
preferences
Re: CDT - Run or debug - the selection cannot be launched [message #233219 is a reply to message #231287] Thu, 23 April 2009 13:47 Go to previous messageGo to next message
Thanks for posting this thread, I had exactly the same problem, and
discovered what I was doing wrong.
You need to highlight the project in the Project Explorer, not one of the
other project files, and then you can select Run -> Run As -> Local C/C++
Application
Wow, I don't believe I've answered a question on this forum with so little
experience in eclipse. This newsgroup rocks.
Re: CDT - Run or debug - the selection cannot be launched [message #754531 is a reply to message #233219] Wed, 02 November 2011 20:38 Go to previous message
Not really helpful for me. I'm using Eclipse 3.7 (Indigo) and:
- found those preferences
- set them as you told (just switched from "Launch the selected resource..." to "Always launch the previously...")
but there is a problem...
When I use the triangle button to run it, "Run Configurations" window appears.
When I choose to "Run as...' there's "Launch failed. Binary not found." error.
Why wouldn't they create an IDE like e.g. Dev-Cpp? It's just write the code and click Compile&Run. No messing with the settings, and so on...
Previous Topic:Best way to stop the program to run?
Next Topic:Does not find include<iostream.h>
Current Time: Thu Nov 27 20:43:55 EST 2025
Powered by FUDForum. Page generated in 0.04512 seconds
