| ManhattanConnectionRouter ? [message #231227] |
Wed, 28 February 2007 18:17  |
Originally posted by: sunjianing.hotmail.com
Hi group,
i'm writing a project using GEF.
The connections in my diagram work fine with ShortestPathConnectionRouter,
the connections are routed between figures.
But when i use ManhattanConnectionRouter, the connections are orthogonal, it
is what i need, but the connections cross figures too, it is very bad :(
Does anybody here know where is the problem?
I've only changed "ShapeDiagram", here the code block
protected IFigure createFigure() {
Figure f = new FreeformLayer();
f.setBorder(new MarginBorder(3));
f.setLayoutManager(new FreeformLayout());
// Create the static router for the connection layer
ConnectionLayer connLayer =
(ConnectionLayer)getLayer(LayerConstants.CONNECTION_LAYER);
//connLayer.setConnectionRouter(new ShortestPathConnectionRouter(f));
connLayer.setConnectionRouter(new ManhattanConnectionRouter());
return f;
Thanks in advanced.
kevin
| Re: ManhattanConnectionRouter ? [message #231296 is a reply to message #231227] |
Fri, 02 March 2007 10:27  |
Originally posted by: none.unknown.com
There's a feature request open on bugzilla to have an orthogonal router that
would avoid obstacles.
"Kevin Sun" <sunjianing@hotmail.com> wrote in message
news:es52hv$95q$1@utils.eclipse.org...
> Hi group,
> it is what i need, but the connections cross figures too, it is very bad
> return f;
> Thanks in advanced.
> kevin
FUDForum. Page generated in 0.03013 seconds
