Home » Newcomers » Newcomers » problems with the 3.3 RCP-europe version
problems with the 3.3 RCP-europe version [message #231164] Thu, 06 September 2007 02:42 Go to next message
Originally posted by: Mathias.Buchholz.salt-solutions.de
for a plug-in I needed to install eclipse 3.3 RCP/plug-in Version.
After installing and running the error log listed some errors.
after that I used eclipse for looking for updates. It found a patch.
->> five errors.
and the plug-in for that I needed eclipse doesn't run.
What could be the problem?
I also got Java 1.5 and 1.6 at the computer
(in eclipse i switched the runtime to 1.5
MAthias
the errors:
1)
eclipse.buildId=I20070625-1500
java.version=1.4.2_03
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86 -clean
Error
Thu Sep 06 08:36:52 CEST 2007
startup class must implement org.eclipse.ui.IStartup
2)
Error
Bad extension specification
3)
Error
Unable to execute early startup code for an extension
java.lang.reflect.InvocationTargetException
org.eclipse.ui.internal.EarlyStartupRunnable.getPluginForCom patibility(EarlyStartupRunnable.java:149)
org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartu pRunnable.java:73)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.ui.internal.Workbench$54.run(Workbench.java:2190 )
Caused by: org.eclipse.core.runtime.CoreException: Problems encountered
starting up plug-in: "org.osgi.framework.BundleException: The activator
org.eclipse.mylyn.internal.compatibility.JavaRuntimeVersionC hecker for
bundle org.eclipse.mylyn.compatibility is invalid".
org.eclipse.core.internal.plugins.PluginDescriptor.throwExce ption(PluginDescriptor.java:296)
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(PluginDescriptor.java:362)
org.eclipse.core.internal.plugins.PluginDescriptor.getPlugin (PluginDescriptor.java:340)
... 9 more
4)
Error
Thu Sep 06 08:36:51 CEST 2007
Unhandled Exception
5)
Error
Problems encountered starting up plug-in:
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
org.eclipse.core.internal.runtime.InternalPlatform.start(Int ernalPlatform.java:877)
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(PluginDescriptor.java:360)
Caused by: java.lang.UnsupportedClassVersionError:
org/eclipse/mylyn/internal/compatibility/JavaRuntimeVersionC hecker
(Unsupported major.minor version 49.0)
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:161)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:501)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:471)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:430)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:413)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:408)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:134)
... 15 more
Root exception:
Re: problems with the 3.3 RCP-europe version [message #231196 is a reply to message #231164] Thu, 06 September 2007 07:59 Go to previous messageGo to next message
--------------040106050106050800040503
Mathias,
Many if not most projects in Europa require Java 5.0 and it seems clear
that you are using a 1.4 JRE. You can run with -clean -debug to see
more details about why plugins are failing to activate. You can use
-vm either in the eclipse.ini (each argument goes on a separate line and
avoid having any spaces in this file) or on the command line to point at
a 4.0 JRE...
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.user/tasks/running_eclipse.htm
Mathias Buchholz wrote:
> Hello,
> ->> five errors.
> What could be the problem? I also got Java 1.5 and 1.6 at the computer
> MAthias
> the errors: 1)
> Error
> 2)
> Error
> 3)
> Error
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> encountered starting up plug-in: "org.osgi.framework.BundleException:
> The activator
> at
> at
> at
> ... 9 more
> 4)
> Error
> Unhandled Exception
> 5)
> Error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> .. 15 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
<html>
<head>
http-equiv="Content-Type">
</head>
Mathias,<br>
<br>
Re: problems with the 3.3 RCP-europe version [message #231205 is a reply to message #231196] Thu, 06 September 2007 08:09 Go to previous messageGo to next message
Ed Merks schrieb:
> Mathias,
Really? Well at least not the Platform SDK because the releng-test are
run against a 1.4 and 1.5. See e.g.
http://download.eclipse.org/eclipse/downloads/drops/M2007090 5-1045/testResults.php
Tom
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: problems with the 3.3 RCP-europe version [message #231223 is a reply to message #231205] Thu, 06 September 2007 08:18 Go to previous messageGo to next message
Tom,
Yes, it's obviously not true for the base platform (which is why I said
"most" and not "all"), but EMF certainly requires it and hence so does
everything downstream from it. So to get a good experience from Europa
as a whole, you will generally need a 5.0 JRE. The EE package for
example, will quietly not function at all without a 5.0 JRE and the
download page has been changed to say that...
Tom Schindl wrote:
> Ed Merks schrieb:
>> Mathias,
> Tom
Re: problems with the 3.3 RCP-europe version [message #231237 is a reply to message #231223] Thu, 06 September 2007 09:14 Go to previous messageGo to next message
hello,
I got the 5.0 RE and the 6.0 RE
(also integrated in eclipse preferences)
with virtual maschine is up-to-date?
as you can see, mine eclipse works withs jvm 1.4.2
thanks for your answers,
Mathias
solved [message #231268 is a reply to message #231237] Thu, 06 September 2007 10:06 Go to previous messageGo to next message
thanks for help, it was useful.
although I got a 1.5 Runtime eclipse only recognised the jvm of the 142
runtime
THANKS
Re: solved [message #231317 is a reply to message #231268] Thu, 06 September 2007 11:47 Go to previous messageGo to next message
Then this has to be reported to the EPP-Project and the download page
has to be updated to reflect this.
Tom
Mathias Buchholz schrieb:
> Hello,
> runtime
> THANKS
Re: solved [message #231320 is a reply to message #231317] Thu, 06 September 2007 12:17 Go to previous message
Tom,
Probably this is an issue of which JRE is on the path and hence ends up
being found by default. I'm just guessing though...
> Tom
>> Hello,
>> 142 runtime
>> THANKS
Previous Topic:how to create user interface inside the eclipse.
Next Topic:I'm learning
Current Time: Mon Sep 15 14:46:47 EDT 2025
Powered by FUDForum. Page generated in 0.10181 seconds
