enable and set debug options [message #22576] |
Thu, 01 May 2008 11:36  |
I would like to debug certain behavior, starting with completion.
I found conditional debugging statements in the DLTK source code referring
to these constants:
public static final boolean DEBUG = Boolean.valueOf(
Platform.getDebugOption("org.eclipse.dltk.core/debug")).booleanValue();
//$NON-NLS-1$
public static final boolean DEBUG_COMPLETION = Boolean.valueOf(
Platform.getDebugOption("org.eclipse.dltk.core/debugCompletion ")).booleanValue();
//$NON-NLS-1$
I googled Eclipse getDebugOption and found this page:
http://wiki.eclipse.org/FAQ_How_do_I_use_the_platform_debug_ tracing_facility%3F
I created a .options file, and put it into C:\java\eclipse, and it has this
contents:
org.eclipse.dltk.core/debug=true
org.eclipse.dltk.core/debugCompletion=true
I invoked Eclipse with the -debug flag and it said this:
Debug options:
file:/C:/Java/eclipse/.options loaded
When I attempt to debug the line which sets DEBUG_SELECTION, it didn't step
into getDebugOptions, it simply stepped into Boolean.valueOf() and said the
string value was null.
So, how do I set debug options?
Chuck
Re: enable and set debug options [message #22796 is a reply to message #22619] |
Sun, 04 May 2008 08:26   |
Hi Chuck,
You also could specify this options from "Run Configurations" dialog -> Then select your launch shortcut -> Tracing tab
and set required options.
Andrei Sobolev.
> I'm not sure why it wasn't working before - but I believe it is working now.
> Chuck
> "Chuck Doucette" <cdoucette@vaultus.com> wrote in message
> news:fvco3p$nai$1@build.eclipse.org...
>> to these constants:
>> //$NON-NLS-1$
>> //$NON-NLS-1$
>> this contents:
>> Debug options:
>> step into getDebugOptions, it simply stepped into Boolean.valueOf() and
>> said the string value was null.
>> Thanks,
>> Chuck
Re: enable and set debug options [message #22837 is a reply to message #22796] |
Sun, 04 May 2008 11:35  |
That didn't work for me since none of the DLTK plugins were listed in the
tracing tab (and therefore couldn't be selected and enabled).
Chuck
"Andrei Sobolev" <haiodo@xored.com> wrote in message
news:fvka1e$8td$2@build.eclipse.org...
> Hi Chuck,
> Best regards,
> Andrei Sobolev.
>> now.
>> Chuck
>>> referring
>>> to these constants:
>>> //$NON-NLS-1$
>>> //$NON-NLS-1$
>>> this contents:
>>> Debug options:
>>> Thanks,
>>> Chuck
FUDForum. Page generated in 0.84296 seconds
