Home » Archived » XML Schema Definition (XSD) » XSDParser
XSDParser [message #22575] Fri, 16 May 2003 03:49 Go to next message
Originally posted by: paechoi.earthlink.net
When I am creating a DOM by using the XSDParser, it seems
like dropping the comment node, i.e., <!-- ... -->.
I need to preserve the comments. How should we do it?
Any comments?
Pae
Re: XSDParser [message #22754 is a reply to message #22575] Fri, 16 May 2003 10:57 Go to previous message
Pae,
Thanks for pointing this out. I've upgraded XSDParser to support a
LexicalHandler that will create Comment nodes. This will be available
with the next code drop.
> Any comments?
> Pae
Re: XSDParser [message #572150 is a reply to message #22575] Fri, 16 May 2003 10:57 Go to previous message
Pae,
> Any comments?
> Pae
Previous Topic:XSDParser
Next Topic:[FYI] More Tests with Schemas defined in WSDL
Current Time: Thu Nov 06 21:07:49 EST 2025
Powered by FUDForum. Page generated in 0.24478 seconds
