Home » Eclipse Projects » JFace » [CellEditor] Find the currently active CellEditor in a TableViewer (3.3 API)
[CellEditor] Find the currently active CellEditor in a TableViewer (3.3 API) [message #22551] Wed, 22 July 2009 08:52 Go to next message
Originally posted by: bjoern.bjoernfischer.de
Hello everybody,
I have different CellEditors attached to the columns of my TableViewer
via TableEditingSupport (TableViewerEditor.create(...) /
column.setEditingSupport(...)).
At runtime I want to invoke a method on the currently active CellEditor
(in this case show the dialog of a customized DialogCellEditor). Is
there a way to find the currently active CellEditor programmatically? I
cannot use the method TableViewer#getCellEditors() since it is part of
the legacy (3.2) API and I have not found a 3.3 pendant.
Björn
Re: [CellEditor] Find the currently active CellEditor in a TableViewer (3.3 API) [message #23790 is a reply to message #22551] Fri, 24 July 2009 03:14 Go to previous message
Really nobody who can help me? Is there no way to get the active
CellEditor from a TableViewer? Currently I use a very dirty workaround
that should really not go in a released version :-(
I hope someone has an idea about this. Thanks in advance for any hint.
Björn
Björn Fischer schrieb:
> Hello everybody,
> Björn
Previous Topic:Validate text in TextCellEditor after input
Next Topic:ObservableValueEditingSupport sets model value 1st time even if not changed
Current Time: Mon Jul 14 15:49:04 EDT 2025
Powered by FUDForum. Page generated in 0.27839 seconds
