Home » Newcomers » Newcomers » Error Message
Error Message [message #230652] Tue, 04 September 2007 00:39 Go to next message
Originally posted by: testdummy4444.yahoo.com
I get this error message when I try to debug a php script:
The debug session could not be started.
Please make sure that the debugger is properly configured as a php.ini
directive.
I have no clue as to how to do this. Help!!
Re: Error Message [message #230657 is a reply to message #230652] Tue, 04 September 2007 01:22 Go to previous messageGo to next message
> directive.
Hey,
the message pretty much says it. Open your php.ini file and change the
debug directive. Usually this file contains a lot of comments so that
should be easy.
Felix
Re: Error Message [message #230846 is a reply to message #230657] Tue, 04 September 2007 16:36 Go to previous messageGo to next message
Thanks for the reply,
I opened up the php.ini file and did a search for the word "debug" and the
only reference was this:
;report_zend_debug = 0
I uncommented the line and still got the same error message.
I then changed the value to 1 with no luck--same error message.
Any other suggestions?
Re: Error Message [message #230866 is a reply to message #230846] Tue, 04 September 2007 18:46 Go to previous messageGo to next message
> the only reference was this:
rtfm
This concerns two things:
1. How to setup php to enable debug outputs should described on a
million of web pages out there. Not speaking of the official php
installation + manual documents.
2. You probably would learn more if you´d manually scan through the
config file instead of doing a simple search for "debug". To have seen
that file at least once may be valuable. And you´d probably have already
found the settings you need to change...
Felix
Re: Error Message [message #230899 is a reply to message #230866] Wed, 05 September 2007 00:57 Go to previous messageGo to next message
I read over the php.ini file very carefully and still did not see anything
that would solve my problem. I did numerous searches relating to enabling
debug output and while there were some, none of which covered my problem.
I copied the error message to the Google search engine and there was only
one hit and it was in a foreign language.
Problem Solved [message #231107 is a reply to message #230899] Wed, 05 September 2007 20:11 Go to previous messageGo to next message
I solved my problem with no thanks to anyone else. If any poor sole has
the same problem as I have described here are the steps that I took to
solve my problem.
1. Download and unzip/install Java Environment:
http://www.java.com/en/download/
2. Download and unzip this file:
pdt-all-in-one-incubation-S20070826_M3-win32.zip
3. Download and unzip this file:
org.zend.php.debug_feature-5.2.10.v20070826.zip
Once you unzip the file from step 3, it will have a folder called eclipse
and in this folder it will have two more folders, one called features and
one called plugins. The all-in-one file that you downloaded and unzipped
in step 2 also has a eclipse folder that has two folders (among others)
called features and plugins. Copy everything in the features folders from
step 3 into the features folder in step 2 (you will have to overwrite the
files). Then do the same for the plug-ins folder, i.e., copy everything
from the plugins folder in step 3 to the plugins folder in step 2.
My php IDE now works perfect with debugging out the a_s h_le!!!
Re: Problem Solved [message #231230 is a reply to message #231107] Thu, 06 September 2007 08:47 Go to previous messageGo to next message
Originally posted by: ns_dkerber.ns_WarrenRogersAssociates.com
In article <b764168dbc18f066586b52afb53857ba$1@www.eclipse.org>,
testdummy4444@yahoo.com says...
> solve my problem.
Which problem is that? If you had responded to the previous post, so
this message was attached to the original thread, it would have been a
lot more useful to future readers. Right now, all I can tell is that it
had something to do with PHP, and wouldn't even know that if you hadn't
put that last line in the message.
Remove the ns_ from if replying by e-mail (but keep posts in the
newsgroups if possible).
Re: Problem Solved [message #231337 is a reply to message #231230] Thu, 06 September 2007 14:14 Go to previous messageGo to next message
Originally posted by: bert.iphouse.com
ns_dkerber@ns_WarrenRogersAssociates.com () wrote in
news:MPG.2149c0d77b86c8d9896d7@news.eclipse.org:
>> sole has the same problem as I have described here are the steps
>> that I took to solve my problem.
> so this message was attached to the original thread, it would have
> been a lot more useful to future readers.
Actually, he did. His first post
Subject: Error Message
Date: Tue, 4 Sep 2007 04:39:28 +0000 (UTC)
Message-ID: <f60d234e88e1cf895b7313cf4992f846$1@www.eclipse.org>
is the first item in the "References:" header chain, which appears to
be completely intact.
> Right now, all I can tell is that it had something to do with PHP,
> and wouldn't even know that if you hadn't put that last line in the
> message.
Bert Hyman | St. Paul, MN | bert@iphouse.com
Re: Problem Solved [message #231448 is a reply to message #231337] Thu, 06 September 2007 20:45 Go to previous message
In article <Xns99A3869DF7FF0VeebleFetzer@206.191.52.34>,
bert@iphouse.com says...
Ok; I wouldn't have known to look for that. My newsreader (Gravity)
threads by subject.
Previous Topic:how to build one modified plugin
Next Topic:"No suitable driver" message
Current Time: Sun Aug 31 08:03:02 EDT 2025
Powered by FUDForum. Page generated in 0.32682 seconds
