Home » Eclipse Projects » Buckminster dev » Problem with features on a buckminster created updatesite
Problem with features on a buckminster created updatesite [message #22539] Mon, 21 July 2008 14:30 Go to next message
Originally posted by: cbutt.iona.com
I've created an update site using buckminster. Recently I added a couple
of dependency features (I am not building them just re-publishing them) to
this site to make it easier internally to perform updates. However, these
new features are not being packaged correctly. Only the feature.xml and
META-INF/MANIFEST.MF are included in the created site. I'm missing the
feature.properties, epl-v10.html and META-INF/eclipse.inf files. This is
causing display problems when using the update site.
Any ideas or settings that I should be aware of that may be causing this
strange behavior?
Chris
Re: Problem with features on a buckminster created updatesite [message #22715 is a reply to message #22539] Mon, 21 July 2008 15:52 Go to previous message
Hi Chris,
Check the build.properties file in your feature. It should contain a
bin.includes property that lists the desired content of the feature jar.
Thomas Hallgren
Chris Butt wrote:
> to this site to make it easier internally to perform updates. However,
> these new features are not being packaged correctly. Only the
> feature.xml and META-INF/MANIFEST.MF are included in the created site.
> I'm missing the feature.properties, epl-v10.html and
> META-INF/eclipse.inf files. This is causing display problems when using
> the update site.
> strange behavior?
> Chris
Previous Topic:Re: [buckminster-dev] Hello XML World Example error
Next Topic:Non Java projects Proposal
Current Time: Fri Jul 18 23:32:19 EDT 2025
Powered by FUDForum. Page generated in 0.07871 seconds
