Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » completion proposals - not matched to prefix?
completion proposals - not matched to prefix? [message #22530] Wed, 30 April 2008 19:41 Go to next message
I have developed a prototype editor for our scripting language based on your
tutorial:
http://wiki.eclipse.org/A_guide_to_building_a_DLTK-based_lan guage_IDE
We now would like to figure out how to turn the prototype into a real
editor.
The first thing that was obvious was that it was proposing every keyword in
the language as a possible completion without regard for:
a) whether or not it starts with the same prefix
b) whether it fits into the syntax at that point
Doing b may be difficult - but a should be quite easy.
I did run my prototype editor in the debugger and found that it accepted or
rejected possible templates based on whether the name of the template
started with the same prefix as what the user had typed. This did not seem
to be the case for adding keywords.
How can I get at least the prefix to constrain possible completions?
Also, is there any documentation or even Java doc for DLTK?
Chuck
Re: completion proposals - not matched to prefix? [message #22708 is a reply to message #22530] Fri, 02 May 2008 17:07 Go to previous messageGo to next message
I'm still stuck on this problem, and I would appreciate some input.
The issue is specifically with ICompletionEngine, and the method:
void complete(ISourceModule module, int position, int pos)
I found where it is called from Openable.codeComplete:
engine.complete(cu, position, 0);
I can use ISourceModule, and call this method:
String getSourceContents();
From, that, I assume I can use position to determine where someone is trying
to perform completion.
What I don't know is how to determine what if anything they have typed
before attempting to do completion (which I assume they haven't saved yet).
I know this is prefix is available for evaluating matching template names.
I don't remember where that source is.
Chuck
"Chuck Doucette" <cdoucette@vaultus.com> wrote in message
news:fvb05h$jgb$1@build.eclipse.org...
>your tutorial:
> editor.
> in the language as a possible completion without regard for:
> or rejected possible templates based on whether the name of the template
> Chuck
Re: completion proposals - not matched to prefix? [message #22752 is a reply to message #22708] Sun, 04 May 2008 08:23 Go to previous messageGo to next message
Hi Chuck,
Tutorial we provided contain only basic information about some DLTK parts.
For more complex implementation please refer to our language implementations( Tcl, Ruby ).
SourceModules use special structure named Buffer.
All changes from user are be in this buffer.
So then you call getSourceContents() and if buffer exists content from buffer will be returned.
Andrei Sobolev.
> Chuck
>> your tutorial:
>> editor.
>> Thanks,
>> Chuck
Re: completion proposals - not matched to prefix? [message #22880 is a reply to message #22752] Sun, 04 May 2008 11:51 Go to previous messageGo to next message
I already said that apparently I could call ISourceModule.getSourceContents.
I assume that method will return the original contents of the buffer.
I want to get the current contents, and specifically what was just typed
before invoking completion.
Is that possible to obtain? If so, how?
I found the template code that I was referring to in the class
ScriptTemplateCompletionProcessor:
public ICompletionProposal[] computeCompletionProposals(ITextViewer viewer,
int offset) {
It calls this:
String prefix = extractPrefix(viewer, offset);
That method is defined here:
package org.eclipse.jface.text.templates;
class TemplateCompletionProcessor
as follows:
* Heuristically extracts the prefix used for determining template relevance
* from the viewer's document. The default implementation returns the String
from
* offset backwards that forms a java identifier.
* @param viewer the viewer
* @param offset offset into document
* @return the prefix to consider
* @see #getRelevance(Template, String)
protected String extractPrefix(ITextViewer viewer, int offset) {
This would give me exactly what I (and probably many others) are looking
for.
It makes no sense to return possible completions (template or otherwise)
that don't match the prefix.
For now, I guess I will attempt to emulate this code in my classes - but
ideally it would be functionality offerred by DLTK.
I will look at some of your complete implementations, like JavaScript,
rather than the tutorial example for Python.
Chuck
"Andrei Sobolev" <haiodo@xored.com> wrote in message
news:fvk9sd$8td$1@build.eclipse.org...
> Hi Chuck,
>> trying
>> yet).
> Best regards,
> Andrei Sobolev.
>> names.
>> Thanks,
>> Chuck
>>> your tutorial:
>>> editor.
>>> seem
>>> Thanks,
>>> Chuck
Re: completion proposals - not matched to prefix? [message #22968 is a reply to message #22880] Mon, 05 May 2008 15:07 Go to previous messageGo to next message
It appears that perhaps my class should extend the class
ScriptCompletionEngine
rather than implement the interface ICompletionEngine (as was done in the
tutorial).
The problem is that there are 4 methods that need to be defined, and there
is no documentation that I can find on how to define them:
protected String processFieldName(IField field, String token) {
// TODO Auto-generated method stub
return null;
protected String processMethodName(IMethod method, String token) {
return null;
protected String processTypeName(IType method, String token) {
return null;
public IAssistParser getParser() {
return null;
Also, IAssistParser is not documented either.
Chuck
news:fvkm4a$ia3$1@build.eclipse.org...
> It calls this:
> as follows:
> relevance
> String from
> for.
> Chuck
>> Hi Chuck,
>> parts.
>>> trying
>>> yet).
>> Best regards,
>> Andrei Sobolev.
>>> names.
>>> Thanks,
>>> Chuck
>>>> your tutorial:
>>>> editor.
>>>> keyword
>>>> accepted
>>>> template
>>>> seem
>>>> Thanks,
>>>> Chuck
Re: completion proposals - not matched to prefix? [message #23055 is a reply to message #22968] Mon, 05 May 2008 18:07 Go to previous messageGo to next message
I downloaded the latest Integration/Incubation build, with all of the
language toolkit bundles.
As far as I could tell, only JavaScript defines a completion engine, and
they do extend ScriptCompletionEngine rather than simply implement
ICompletionEngine.
I didn't see a completion engine defined in Ruby, Tcl, or Python.
Chuck
news:fvnlvq$qjb$1@build.eclipse.org...
> tutorial).
> @Override
> return null;
> @Override
> return null;
> @Override
> return null;
> @Override
> return null;
> Chuck
>> It calls this:
>> as follows:
>> relevance
>> String from
>> for.
>> Thanks,
>> Chuck
>>> Hi Chuck,
>>> parts.
>>>> trying
>>>> yet).
>>> Best regards,
>>> Andrei Sobolev.
>>>> names.
>>>> Thanks,
>>>> Chuck
>>>>> on
>>>>> your tutorial:
>>>>> editor.
>>>>> keyword
>>>>> accepted
>>>>> template
>>>>> seem
>>>>> Thanks,
>>>>> Chuck
Re: completion proposals - not matched to prefix? [message #23098 is a reply to message #23055] Mon, 05 May 2008 18:24 Go to previous messageGo to next message
I looked again and did find a completion engined defined for both Ruby and
Tcl.
Again they both extended ScriptCompletionEngine rather than implement
ICompletionEngine.
Chuck
news:fvo0ib$f50$1@build.eclipse.org...
> ICompletionEngine.
> Chuck
>> tutorial).
>> there is no documentation that I can find on how to define them:
>> @Override
>> return null;
>> @Override
>> return null;
>> @Override
>> return null;
>> @Override
>> return null;
>> Thanks,
>> Chuck
>>> It calls this:
>>> as follows:
>>> relevance
>>> String from
>>> for.
>>> Thanks,
>>> Chuck
>>>> Hi Chuck,
>>>> parts.
>>>>> trying
>>>>> yet).
>>>> Best regards,
>>>> Andrei Sobolev.
>>>>> names.
>>>>> Thanks,
>>>>> Chuck
>>>>>> on
>>>>>> your tutorial:
>>>>>> editor.
>>>>>> keyword
>>>>>> accepted
>>>>>> template
>>>>>> seem
>>>>>> Thanks,
>>>>>> Chuck
Re: completion proposals - not matched to prefix? [message #23141 is a reply to message #23098] Mon, 05 May 2008 19:48 Go to previous messageGo to next message
I found
org.eclipse.dltk.ruby.internal.core.codeassist.RubyCompletio nEngine.getWordStarting
and copied it to my class. Ideally, this functionality should be moved to a
base class.
I gather the source module contents are the current contents, and the offset
is where the cursor is
when you request completion. So, if you ask what did someone just type, you
can assume it was the previous word/identifier.
1) getWordStarting takes a maxLength. Pratically - the previous token
wouldn't be very long - but why must there be a limit?
I may rewrite this method.
2) I now properly filter my keyword proposals to only return those
starting with the previous token.
3) Unfortunately, the full keyword proposals are always added to the
existing token prefix, i.e.:
fo
becomes
fofor
Chuck
news:fvo1ib$19c$1@build.eclipse.org...
>Tcl.
> ICompletionEngine.
> Chuck
>> ICompletionEngine.
>> Chuck
>>> the tutorial).
>>> @Override
>>> return null;
>>> @Override
>>> return null;
>>> @Override
>>> return null;
>>> @Override
>>> return null;
>>> Thanks,
>>> Chuck
>>>> typed before invoking completion.
>>>> It calls this:
>>>> as follows:
>>>> relevance
>>>> String from
>>>> looking for.
>>>> otherwise) that don't match the prefix.
>>>> but ideally it would be functionality offerred by DLTK.
>>>> Thanks,
>>>> Chuck
>>>>> Hi Chuck,
>>>>> parts.
>>>>>> trying
>>>>>> typed
>>>>>> yet).
>>>>> Best regards,
>>>>> Andrei Sobolev.
>>>>>> names.
>>>>>> Thanks,
>>>>>> Chuck
>>>>>>> on
>>>>>>> your tutorial:
>>>>>>> real
>>>>>>> editor.
>>>>>>> keyword
>>>>>>> accepted
>>>>>>> template
>>>>>>> not seem
>>>>>>> Thanks,
>>>>>>> Chuck
Re: completion proposals - not matched to prefix? [message #23179 is a reply to message #23141] Mon, 05 May 2008 20:14 Go to previous messageGo to next message
Once I set the offset to the length of the preceeding token,
everything seems to work fine as I expected.
Chuck
news:fvo6er$655$1@build.eclipse.org...
>I found
> a base class.
> offset is where the cursor is
> you can assume it was the previous word/identifier.
> fo
> becomes
> fofor
> Chuck
>>Tcl.
>> ICompletionEngine.
>> Chuck
>>> ICompletionEngine.
>>> Chuck
>>>> the tutorial).
>>>> @Override
>>>> return null;
>>>> @Override
>>>> return null;
>>>> @Override
>>>> return null;
>>>> @Override
>>>> return null;
>>>> Thanks,
>>>> Chuck
>>>>> It calls this:
>>>>> as follows:
>>>>> relevance
>>>>> String from
>>>>> looking for.
>>>>> Thanks,
>>>>> Chuck
>>>>>> Hi Chuck,
>>>>>> parts.
>>>>>>> is trying
>>>>>>> typed
>>>>>>> saved yet).
>>>>>> Best regards,
>>>>>> Andrei Sobolev.
>>>>>>> names.
>>>>>>> Thanks,
>>>>>>> Chuck
>>>>>>>> based on
>>>>>>>> your tutorial:
>>>>>>>> real
>>>>>>>> editor.
>>>>>>>> keyword
>>>>>>>> accepted
>>>>>>>> template
>>>>>>>> not seem
>>>>>>>> completions?
>>>>>>>> Thanks,
>>>>>>>> Chuck
Re: completion proposals - not matched to prefix? [message #23214 is a reply to message #23179] Tue, 06 May 2008 01:36 Go to previous message
Hi Chuck,
Nice to see it.
Andrei Sobolev.
> Chuck
>> I found
>> a base class.
>> fo
>> becomes
>> fofor
>> Chuck
>>> Tcl.
>>> ICompletionEngine.
>>> Chuck
>>>> ICompletionEngine.
>>>> Chuck
>>>>> the tutorial).
>>>>> @Override
>>>>> return null;
>>>>> @Override
>>>>> return null;
>>>>> @Override
>>>>> return null;
>>>>> @Override
>>>>> return null;
>>>>> Thanks,
>>>>> Chuck
>>>>>> It calls this:
>>>>>> as follows:
>>>>>> relevance
>>>>>> String from
>>>>>> looking for.
>>>>>> Thanks,
>>>>>> Chuck
>>>>>>> Hi Chuck,
>>>>>>> parts.
>>>>>>>> is trying
>>>>>>>> typed
>>>>>>>> saved yet).
>>>>>>> Best regards,
>>>>>>> Andrei Sobolev.
>>>>>>>> names.
>>>>>>>> Thanks,
>>>>>>>> Chuck
>>>>>>>>> based on
>>>>>>>>> your tutorial:
>>>>>>>>> real
>>>>>>>>> editor.
>>>>>>>>> keyword
>>>>>>>>> accepted
>>>>>>>>> template
>>>>>>>>> not seem
>>>>>>>>> completions?
>>>>>>>>> Thanks,
>>>>>>>>> Chuck
Previous Topic:DLTK javadoc - do it yourself
Next Topic:unable to find method declarations
Current Time: Tue Jul 22 01:53:10 EDT 2025
Powered by FUDForum. Page generated in 0.06111 seconds
