GEF ChangeConstraint Problem [message #230488] |
Mon, 12 February 2007 19:13  |
Hi ,
I am using GEF/Draw2d to create one of my custom plot view. I have a
data point which should be draggable inside the plot area. So i used
XYLayoutEditPolicy on the Parent of the data point which is a rectangle
with the XYLayout set on that.
I am not using the CreateCommand to create the data point. I have the
datapoints as the child of the plot area. I did create an object of the
data point on my own.
Now I can see the data point on the View, but it is not moving when i
drag that. I did implement the ChangeConstraintCommand but no use.
public class SetConstraintCommand extends
org.eclipse.gef.commands.Command {
private Rectangle oldBounds;
private Rectangle newBounds;
private ChangeBoundsRequest request;
private DataPoint part;
public SetConstraintCommand(DataPoint part, ChangeBoundsRequest
req,Rectangle newBounds) {
this.part = part;
this.request = req;
this.newBounds= newBounds;
setLabel("POINT_MOVE");
public boolean canExecute() {
System.out.println("Checking whether the ChangeConstraint can be
executed");
Object type = request.getType();
// make sure the Request is of a type we support:
return (RequestConstants.REQ_MOVE.equals(type)
|| RequestConstants.REQ_MOVE_CHILDREN.equals(type));
public void execute() {
oldBounds = new Rectangle(part.getLocation(),part.getSize());
redo();
public void redo() {
part.setSize(new Dimension(10,10));
part.setLocation(newBounds.getLocation());
public void setPoint(DataPoint part) {
this.part = part;
public void undo() {
part.setLocation(oldBounds.getLocation());
and on my PlotEditPart i added the
installEditPolicy(EditPolicy.LAYOUT_ROLE,new
DataPointXYLayoutEditPolicy());
and i used to create the command as follows..
protected Command createChangeConstraintCommand(ChangeBoundsRequest req,
EditPart part, Object constraint) {
System.out.println("createChangeConstraintCommand with Request");
return new SetConstraintCommand((BoundaryPoint) part.getModel(),
req,
(Rectangle) constraint);
But nothing happens when i click and drag the point. Any suggestions ?
Thanks in advance,
Kathir.
Re: GEF ChangeConstraint Problem [message #230553 is a reply to message #230488] |
Tue, 13 February 2007 03:33   |
Originally posted by: jakub.jurkiewicz.gmail.com
I cannot see what could be wrong, so could you post the code where you
create the data points on your own?
regards,
Jakub Jurkiewicz
kathir wrote:
> Hi ,
> this.part = part;
> this.request = req;
> executed");
> redo();
> this.part = part;
> req,
> Thanks in advance,
> Kathir.
Re: GEF ChangeConstraint Problem [message #230586 is a reply to message #230553] |
Tue, 13 February 2007 12:56  |
here is the createPartControl(Composite par) block in which i create a
single datapoint
createPartControl(Composite parent)
graphicalViewer = new GraphicalViewerImpl();
rootEditPart = new ScalableRootEditPart();
editPartFactory = new MyPlotEditPartFactory();
graphicalViewer.setRootEditPart(rootEditPart);
graphicalViewer.setEditPartFactory(editPartFactory);
graphicalViewer.createControl(parent);
plot = new MyPlot();
DataPoint point = new DataPoint(0,0); // I just created one data point
along the axis. The //
figure is a rectangle of 10,10 size.
plot.addPoint(point);
graphicalViewer.setContents(plot);
Now i can see the point in the view. But it is not draggable.
BR,
Kathir.
> regards,
> Jakub Jurkiewicz
> kathir wrote:
>> Hi ,
>> rectangle with the XYLayout set on that.
>> the data point on my own.
>> this.part = part;
>> this.request = req;
>> be executed");
>> redo();
>> this.part = part;
>> protected Command
>> part.getModel(), req,
>> Thanks in advance,
>> Kathir.
FUDForum. Page generated in 0.05746 seconds
