Home » Archived » M2M (model-to-model transformation) » How to distinguish several in- and out-models
How to distinguish several in- and out-models [message #22520] Fri, 09 March 2007 12:22 Go to next message
Originally posted by: kehrer.hdm-stuttgart.de
I have the following situation:
An ATL transformation with several in- and out-models conorming to the same
metamodel (In my case: UML2)
Looks like this.
create OUT : UML2, TRACE_OUT : UML2 from IN : UML2, TRACE_IN : UML2;
now my problem:
how can I refer to those models in the rule specification?
The examples always consider exactly ONE input and output model.
But how can I tell the ATL-engine, in which model to create or match the
elements?
Thanks for any hints
Timo
Re: How to distinguish several in- and out-models [message #23010 is a reply to message #22520] Mon, 12 March 2007 07:40 Go to previous messageGo to next message
Originally posted by: marcos.didonet-del-fabro.univ-nantes.fr
in the guard, you can use the method allInstancesFrom, like this:
rule MultipleInput {
from
c : UML2!Class (UML2!Class.allInstancesFrom('IN')->exists ( e | e = c) )
to
Concerning the output models, try to use different identifiers for the output metamodels,
as shown in the example below:
create OUT : UML_OUT1, TRACE_OUT : UML_OUT2 from ...
rule MultipleOutput {
to
model1: UML_OUT1 (
model2 : UML_OUT2 (
Marcos.
Timo Kehrer wrote:
> Hello,
> Looks like this.
> now my problem:
> elements?
> Timo
Re: How to distinguish several in- and out-models [message #23493 is a reply to message #22520] Thu, 15 March 2007 07:16 Go to previous message
Originally posted by: ajossic.sodius.com
Hi Timo Kehrer,
I have fix this problem through this following way:
I use two helpers that tell me if the entity come from the appropriate
model:
//header
create merge : ATL from left : ATL, right : ATL;
helper context ATL!Element def : isLeft : Boolean =
ATL!Element.allInstancesFrom('left')
->exists(e | e = self)
// helper
helper context ATL!Element def : isRight : Boolean =
ATL!Element.allInstancesFrom('right')
I used these to distinguish from which model come from the entities:
//rules
rule matchedRuleFromLeft {
from
lelftMR : ATL!MatchedRule (
lelftMR.isLeft
to
m : ATL!MatchedRule (
rule matchedRuleFromRight {
from
rightMR: ATL!MatchedRule (
rightMR.isRight
to
To optimize your code, i advice you to implement the helpers on your
top-level metatype.
I hope that helps you.
Best Regards,
Albin.
Albin JOSSIC (ajossic@sodius.com)
SODIUS
6, rue Cornouaille
44319 Nantes - France
Phone: +33 (0)2 28 23 54 34
www.mdworkbench.com
Draw more value from your model
Timo Kehrer a écrit :
> Hello,
the same metamodel (In my case: UML2)
> Looks like this.
> now my problem:
the elements?
> Timo
Previous Topic:[ATL] New ATL use case: Implementing two business rule languages: PRR and IRL
Next Topic:derived classes
Current Time: Mon Sep 01 05:17:21 EDT 2025
Powered by FUDForum. Page generated in 0.26313 seconds
