Home » Language IDEs » ServerTools (WTP) » How do I connect a default assistant to the SourceViewer?
How do I connect a default assistant to the SourceViewer? [message #230373] Wed, 15 April 2009 10:04
How do I connect a default assistant to the SourceViewer, is the same
as in XMLEditor?
private TextViewer createFineXmlViewer(Composite parent){
SourceViewerConfiguration sourceViewerConfiguration = new
StructuredTextViewerConfigurationXML();
String contentTypeID = ContentTypeIdForXML.ContentTypeID_XML;
SourceViewer fineXmlViewer = new StructuredTextViewer(parent, null,
null, false, SWT.BORDER | SWT.V_SCROLL | SWT.H_SCROLL);
((StructuredTextViewer)
fineXmlViewer).getTextWidget().setFont(JFaceResources.getFon t( "org.eclipse.wst.sse.ui.textfont"));
IStructuredModel scratchModel =
StructuredModelManager.getModelManager().createUnManagedStru cturedModelFor(contentTypeID);
IDocument document = scratchModel.getStructuredDocument();
fineXmlViewer.setDocument(document);
fineXmlViewer.configure(sourceViewerConfiguration);
return fineXmlViewer;
What else should I add to the code?
Previous Topic:WST not publishing JEE Module Dependency
Next Topic:HTML Source Formatting
Current Time: Sun Aug 31 14:25:12 EDT 2025
Powered by FUDForum. Page generated in 0.02770 seconds
