Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » ITraversalStrategy breaking 'validation.constraintBindings' ?
ITraversalStrategy breaking 'validation.constraintBindings' ? [message #22464] Wed, 15 February 2006 12:38 Go to next message
I have a usecase declaring constraints targeted to a particular EClass but
requiring additional target refinement
based on the EObject instance state. In other words, not every instance of
that type is the appropriate target.
I have tried to use 'validation.constraintBindings' extension point to
define a <clientContext> with <enablement> or custom <selector> enforcing my
specific condition.
This works, but only partly.
It stops working in case I declare multiple constraints bound in different
client contexts and
these constraints are targeted on EClasses whose instances are in the same
validated sub-tree.
The reason is that the default strategy used by IBatchValidator assumes that
only the root elements of the traversal
may be in different client contexts.
I have found all this clearly described in ITraversalStrategy interface and
I understand the reasons for introducing
these 'optimistic' strategies. What only confused me a bit was that my
EObject was checked
during the validation step but no applicable constraints were found.
Of course, I can provide my own 'pessimistic' strategy and everything works
fine, just with the cost of frequent
re-computing of the client context.
But I still have a feeling that this is not the right solution.
Is there any better way how to achieve this?
/Radek
Re: ITraversalStrategy breaking 'validation.constraintBindings' ? [message #22639 is a reply to message #22464] Wed, 15 February 2006 18:03 Go to previous messageGo to next message
Hi, Radek,
It may actually be more efficient to simply have your constraints filter out
objects that are not of interest to them (simply returning success) than to
implement a strategy that computes the contexts of every object and finds
the associated bindings. The latter is a lot more work for the VM.
I think that you are trying to apply a finer granularity of classification
of objects with the client contexts than what it was intended for. The
intent of the client context is to determine the "client application" that
"owns" an object in a model, where potentially multiple applications might
be using the same Ecore-defined metamodel in different ways. For example,
multiple applications using the org.eclipse.uml2 metamodel in the same
workbench; one for all-out UML modeling and one for displaying Java
execution traces using sequence diagrams (as in the Hyades profiler).
These applications might have very different requirements for validation of
models: classic well-formedness rules for the modeling application and
performance bottle-neck detection in the profiler.
In your case, you are trying to apply multiple contexts to the same
application. I don't think that will work very well (as you are seeing).
Christian
Radek Dvorak wrote:
> my specific condition.
> client contexts and
> validated sub-tree.
> that only the root elements of the traversal
> and I understand the reasons for introducing
> EObject was checked
> works fine, just with the cost of frequent
> /Radek
Re: ITraversalStrategy breaking 'validation.constraintBindings' ? [message #22944 is a reply to message #22639] Thu, 16 February 2006 09:04 Go to previous messageGo to next message
Hi Christian,
Thanks for the reply.
Clearly, I had that strange feeling that this would be a misuse of client
contexts for too fine granularity.
I only favoured the declarative way over programming first ;-)
Yes, I was thinking about adding the filtering capability to the constraint
itself but there are some complications.
Just few words to clarify my scenario as it might seem a bit untypical
usecase for EMFT validation.
I want to specify audit constraints on diagram notation model elements in
GMF project.
In order to target these constraints to a specific type of diagram I define
the (root) client context with
custom selector, which binds these constraints only to the required diagram
type.
I think conceptually this fits to the client contexts area well, as all
diagram types use the same Ecore-defined notation
metamodel and represent a self-contained client application with its own
aspects for validation.
The finer granularity here is targeting a diagram notation element
encapsulating specific
bussiness model element mapped for visualization.
As for the filtering aware constraint, I did not want to introduce the
selector condition into the constraint validation
logic defined by the GMF client as such condition rather belongs to
internals and may not be language independent.
Then a better option seems to be providing a filtering adapter constraint
delegating the real constraint.
This is probably not feasible as all declared constraints are bound to
either explicit context or default context if there is one.
It looks like there is nothing like detached constraints whose instances can
be retrieved from the validation framework
programmatically. They also all appear at minimum in the default category.
Would be nice to have analogy of optional (enablement | selector) also in
the constraint descriptor, simply extending the logic implemented
by 'boolean IConstraintDescriptor.targetsTypeOf(EObject eObject)'.
On the other hand I understand that this can be considered a minor usecase.
/Radek
"Christian W. Damus" <cdamus@ca.ibm.com> wrote in message
news:dt0bvq$60a$1@utils.eclipse.org...
> Hi, Radek,
> out
> to
> of
> Cheers,
> Christian
> Radek Dvorak wrote:
>> but
>> of
>> different
>> client contexts and
>> same
>> validated sub-tree.
>> EObject was checked
>> Regards,
>> /Radek
Re: ITraversalStrategy breaking 'validation.constraintBindings' ? [message #23074 is a reply to message #22944] Thu, 16 February 2006 09:40 Go to previous messageGo to next message
Hi, Radek,
I think I better understand your situation, now (you may be the judge of
that).
Your usage of client contexts, here, does seem quite reasonable, as it
matches exactly the criteria that I outlined vis-a-vis different clients'
usage of a shared metamodel.
You can avoid recomputing the contexts for every element in the sub-tree if
you know how to detect the boundaries between client contexts. For this
purpose, the ITraversalStrategy interface defines an
isClientContextChanged() query method to detect these boundaries. Perhaps
you can implement a custom traversal strategy to implement this query? It
may not be practical to register it statically against the notation
meta-model if it isn't appropriate for every possible GMF client
application, but you can assign it to the IBatchValidator that you use for
auditing.
HTH,
Christian
Radek Dvorak wrote:
> Hi Christian,
> constraint itself but there are some complications.
> GMF project.
> define the (root) client context with
> diagram type.
> can be retrieved from the validation framework
> usecase.
> /Radek
<snip>
Re: ITraversalStrategy breaking 'validation.constraintBindings' ? [message #23116 is a reply to message #23074] Thu, 16 February 2006 11:37 Go to previous messageGo to next message
Hi Christian,
Thanks for getting me on this direction. I think controlling the client
context switching by
traversal strategy could work for me.
If I got this right, I would switch between contexts for:
1) diagram type specific notation elements with affinity to its bussiness
(visualized) element
(there could be several such client contexts, one per semantic type of
the bussiness element)
2) diagram type specific notation elements only, all handled equally
I also guess that all globally shared validation aspects on diagram notation
elements would be included with each
client context recomputation as well.
That is all I wanted.
Thanks&regards,
/Radek
news:dt22rr$npk$1@utils.eclipse.org...
> Hi, Radek,
> that).
> if
> auditing.
> HTH,
> Christian
> Radek Dvorak wrote:
>> Hi Christian,
>> GMF project.
>> diagram type.
>> category.
>> usecase.
>> Regards,
>> /Radek
> <snip>
Re: ITraversalStrategy breaking 'validation.constraintBindings' ? [message #23197 is a reply to message #23116] Thu, 16 February 2006 12:39 Go to previous message
Radek Dvorak wrote:
> Hi Christian,
Good! I hope it does.
Hopefully, for this case, the structure of the business model will imply
continuity of contexts so that you don't end up recomputing the contexts
frequently.
> notation elements would be included with each
They should be, because every recomputation of contexts is "clean" (from
scratch).
Good luck with it. Do follow up again if you run into more snags (esp. of
the performance variety).
cW
> Thanks&regards,
> /Radek
>> Hi, Radek,
>> that).
>> if
>> Perhaps
>> It may not be practical to register it statically against the notation
>> for auditing.
>> HTH,
>> Christian
<snip>
Re: ITraversalStrategy breaking 'validation.constraintBindings' ? [message #567162 is a reply to message #22464] Wed, 15 February 2006 18:03 Go to previous message
Hi, Radek,
Christian
Radek Dvorak wrote:
> client contexts and
> validated sub-tree.
> EObject was checked
> /Radek
Re: ITraversalStrategy breaking 'validation.constraintBindings' ? [message #567361 is a reply to message #22639] Thu, 16 February 2006 09:04 Go to previous message
Hi Christian,
GMF project.
type.
/Radek
> Hi, Radek,
> out
> to
> of
> Cheers,
> Christian
> Radek Dvorak wrote:
>> but
>> of
>> different
>> client contexts and
>> same
>> validated sub-tree.
>> EObject was checked
>> Regards,
>> /Radek
Re: ITraversalStrategy breaking 'validation.constraintBindings' ? [message #567470 is a reply to message #22944] Thu, 16 February 2006 09:40 Go to previous message
Hi, Radek,
that).
auditing.
HTH,
Christian
Radek Dvorak wrote:
> Hi Christian,
> GMF project.
> diagram type.
> usecase.
> /Radek
<snip>
Re: ITraversalStrategy breaking 'validation.constraintBindings' ? [message #567500 is a reply to message #23074] Thu, 16 February 2006 11:37 Go to previous message
Hi Christian,
Thanks&regards,
/Radek
> Hi, Radek,
> that).
> if
> auditing.
> HTH,
> Christian
> Radek Dvorak wrote:
>> Hi Christian,
>> GMF project.
>> diagram type.
>> category.
>> usecase.
>> Regards,
>> /Radek
> <snip>
Re: ITraversalStrategy breaking 'validation.constraintBindings' ? [message #567555 is a reply to message #23116] Thu, 16 February 2006 12:39 Go to previous message
Radek Dvorak wrote:
> Hi Christian,
frequently.
scratch).
cW
> Thanks&regards,
> /Radek
>> Hi, Radek,
>> that).
>> if
>> Perhaps
>> for auditing.
>> HTH,
>> Christian
<snip>
Previous Topic:Using the OCL parser
Next Topic:[Announce] EMFT OCL 1.0.0 I200602161029 is available
Current Time: Tue Jul 08 20:48:22 EDT 2025
Powered by FUDForum. Page generated in 0.06798 seconds
