Home » Language IDEs » PHP Development Tools (PDT) » wrong syntax error
wrong syntax error [message #22451] Sun, 20 May 2007 14:48 Go to next message
when i typing in pdt i have wrong syntax error:
$tamp_str=$timestamp->item(0)->nodeValue;
error is between item(0) and nodeValue, but code works fine.
How i can remove the error?
Jacek
Re: wrong syntax error [message #22495 is a reply to message #22451] Sun, 20 May 2007 15:28 Go to previous messageGo to next message
Jacek,
Can you please send your class definition part.
Ali
> Jacek
Re: wrong syntax error [message #22884 is a reply to message #22495] Tue, 22 May 2007 07:11 Go to previous messageGo to next message
Ali B. pisze:
> Jacek,
> Cheers,
> Ali
>> Jacek
I use standard DOMXML build in php.
<?php
$xmlDoc = new DOMDocument();
$xmlDoc->load("c:\xmltest.xml");
echo "DomXML <br>\n";
$x= $xmlDoc->documentElement;
$lista = $xmlDoc->getElementsByTagName('sprawa');
foreach($lista as $pozycajlisty)
$timestamp=$pozycajlisty->getElementsByTagName('d_rozprawy');
$timestamp_str=$timestamp->item(0)->nodeValue;
$timestamp_str=str_replace("+02:00","",$timestamp_str);
$timestamp_str=str_replace("T"," ",$timestamp_str);
print $timestamp_str . "\n <br>";
Re: wrong syntax error [message #22928 is a reply to message #22451] Tue, 22 May 2007 07:45 Go to previous message
wolk@jablko.one.pl пишет:
> Jacek
set php5 interpreter for your project (e.g. Project->Properties->PHP Interpreter: check Enable project specific settings, select PHP version PHP 5 or greater)
Previous Topic:status of pdt project + some thoughts
Next Topic:Zend debugger not stopping at brakepoints + bugfix ?
Current Time: Sat Jul 26 23:05:39 EDT 2025
Powered by FUDForum. Page generated in 0.04637 seconds
