Home » Language IDEs » C / C++ IDE (CDT) » Are Make Targets treated as incremental or full build?
Are Make Targets treated as incremental or full build? [message #229650] Wed, 28 January 2009 12:21 Go to next message
I hope this is a sensible question!
When a build is launched through a Make Target does CDT treat this as a
full or incremental build?
Is there a way to configure this? Or could someone point me at the
relevant plug-in code?
Jon
Re: Are Make Targets treated as incremental or full build? [message #229659 is a reply to message #229650] Wed, 28 January 2009 13:13 Go to previous messageGo to next message
I assume you are referring to Make Target view? It is launched as full
build. But this does not make a difference because CDT builder will do
full build anyway. Incremental-ness is achieved exploiting natural
abilities of gmake. Note that you could run arbitrary command in Make
Target view, and so how would notion of incremental build apply?
You could check org.eclipse.cdt.make.internal.core.MakeTarget.build() code.
> Jon
Andrew
Re: Are Make Targets treated as incremental or full build? [message #229772 is a reply to message #229659] Fri, 30 January 2009 06:23 Go to previous message
Hi Andrew,
Thanks for your quick reply.
>> a full or incremental build?
Yes.
Yes, that's true. The problem I'm dealing with is related to using the
Coverity Prevent plug-in. If I've understood it correctly, when we
launch a build through Make Target view Eclipse marks the project as
having performed a full build. This is fair enough as how could it know
what the Make Target will do? But, the problem is that when the project
is marked as having had a full build, the Coverity plug-in won't allow a
"Partial Analysis" even though most of the time we have genuinely only
performed an incremental build.
Perhaps there is a whole other solution to this? I can see the problems
of using Make Targets can not easily or elegantly be worked around.
Thanks!
Jon
>> Thanks,
>> Jon
> Andrew
Previous Topic:include path with environment variables
Next Topic:How disable refresh when launching debugger?
Current Time: Thu Nov 06 13:08:31 EST 2025
Powered by FUDForum. Page generated in 0.03305 seconds
